  • Replies 98
Posted Images
wtf, i did 1 just b4 this and it told me like 3.5 or something, and i thought, thats not right.... so i did it again and got that
oh and thats with iinet
adsl 2 i think?
Edited by Dearlove
Wow, some of you guys have really slow connections. I hope you're not paying too much!! Excluding the people who are testing their work/uni connections I think I'm the fastest thus far?
My home connection
TPG ADSL2+ $70 for 150GB / month via wireless, old plan should upgrade.
EDIT: Will, what connection is that? Your upload is > 1mbps!
BTW, This is UQ
You guys do know that speedtest.net is only supposed to be used as a comparison tool to measure how your line speed was from 1 day to another? It's not used as an industry standard of line testing because it all comes down to location of the server you are doing the test from. You might set it as adelaide and be in perth, however get a faster download speed than if you had of chosen the perth server, because the content server might not be located where you are doing the test from. Not only that but you don't know how many hops it is to the download server from where you are aswel. Only way to really test it is to find a local server, say for instance if you are with iinet, go to ftp.iinet.net.au and download the adsl2.test file and see what your average download speed is from there.
  • 4 weeks later...
  • 7 months later...
  • 7 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
