hey guys,tried lookin up info for 20's but not much came up,all 25 and 26 stuff.anyway. im wanting to know if anyone has seen the results good/bad from modifying the throttle position of a standard plenum to a forward facing one.i know its not designed to have intake on side but wondering if any side affects have been found (leans out cylinders etc.) and if cost worthy of modification.
or if anyone knows of a place to buy a good aftermarket one for 20's that would also be helpfull.
thanks.
Edited by orb4me
https://www.sau.com.au/forums/topic/183057-rb20-plenum/
Pretty sure there is a guy selling a RB26 one modded to fit an RB20.
IMO they look better than any after market job available.
EIther way though, Nissan engineers did a good job with whats on there. Unless your pushing over 300rwkw there is no need to change it.
https://www.sau.com.au/forums/topic/183057-rb20-plenum/#findComment-3319596
I actually read about RB26 plenums on RB20s a while ago now, but its still applicable.
Dyno tests where done prior to removing the standard RB20 plenum, and it was replaced with an RB26 plenum.
After the plenum install it was re-dynoed and the car actually made less power/torque and was less responsive. Did anyone else read this article? I think it was in HPI magazine.
There is nothing wrong with the stock RB20 plenum I have to say, but I can see where your coming from if your issue is the fact that the piping has to run over the engine. I find that annoying when you want to change spart plugs, but thats about it.
If thats the issue then I dont think its worth the trouble to make it/or get a front facing plenum.
If your issue is the length of the piping, then dont even bother. The way its setup is fine, and dont think you will get much better results with shorter piping.
Just my thoughts..
Edited by abu
https://www.sau.com.au/forums/topic/183057-rb20-plenum/#findComment-3319639
ive seen modded rb20 eccs plenums like you described. i think there is a guy selling them on VL turbo forum. my two cents is they look shit. just save and get somthing designed to flow from the side and not lean out cylenders.
His names LEIGH (DUZ360).
I think there around $600 delivered. He is also on SAU I'm pretty sure.
Yep, stock looks fine I reckon, a lot of after market stuff looks shit.
https://www.sau.com.au/forums/topic/183057-rb20-plenum/#findComment-3320278
first question is why do you want to do it?
just to remove an extra 50cm of piping?
reason y is cause its in a 180sx,i got after market bonnet which i don't wanna chop into as its ADR compliant and crap all room to keep it as a crossover design and they do look better facing forward... thanks for all the feed back.i thort they would lean out. i have read the same article on the 26 manifold,main reason for power diff and torque is due to the runner length,id like to get one that bolts onto and uses bottom half of standard manifold to avoid that.trouble is finding one,id pay good money for good stuff, just going through the options, ill check out links given so hope they will help. thank you all.
https://www.sau.com.au/forums/topic/183057-rb20-plenum/#findComment-3321652
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
    • sensible choice....and all 32s should be in yellow
