Ok browsed the forum bout finding an actual organisation or individual that sells a r32 gtr grille
Im actually in Sydney NSW Australia
And Thought by now someone would be reproducing them by the mass with the amount of demand from the gtst boy's wanting to get rid of that ugly flat front, (reminds me so much of the gsl mistubishi cordiain appose to the gsr)
So here goes??
Is there a relyable source inwhich i could obtain a gtr grille from once i purchase my r32 skyline gtst??
Dont mind freight!!
Ok two places to source one from that i know of:
1. Advan Performance @ Silverwater - $170 approx
2. Lincorp @ Camellia (Rosehill) 9638 7193 - $300
The Advan one isnt an original and you'll have to drill two small holes at the back of the grill to tie it to the grill mounts. Delivery time is bloody huge too cos its gotta come from NZ and trust me they're in no hurry to order it for you anyway (mine took 10weeks). However the final product is good.
Lincorp on the other hand sell orginal ones with built in mounting holes... but are almost twice the price
I bought the Advan one...
mr rb20
im actually in the process of buying one hopefully as soon as i sell my car...
just wanted to sus of the grill situation!!!
hopefully i buy one already chopped up and grilled
if not ill have to get rid of the front lip myself with the jigsaw!! :D
hate the gtst front end!! :D
Yeah i dont like the GTST front end much either...
As you can see from my pic under my name i dont have my bonnet on yet... hehe.... as for cutting the lip off yourself, i dont recommend it - the bonnet has layers and as my panel beater said when i asked him for a quote to cut it "it would be a head-f#ck and around $900 including a respray".
GTR bonnets go cheaply and frequently on this site. More often than not they are gunmetal grey for $500-$700. Buy the real thing or go carbon fibre.
You'll need to take out the GTST latch and replace with GTR one around $100 from wrecker...Hope this helps
Oh it can be done but there are two layers that need to be welded together once its cut.
But probably the most difficult part is following the gradual arc of the shape of the nose on the R32 when cutting the lip off.... id hate to have the responsibility of doing it...
this guy on SDU managed to do it however...
http://www.geocities.com/brendonmoses/gts4page14.html
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
