I plan to order some wheels from Japan and want to get it right. They will be 18 x 8.5 but the offset for the rear wheels are confusing me.
I have had a good read through the offset guide, and it appears 99% of people are using a +38 offset on the rears of their skyline.
Offsets offered for the rims I will be ordering are +36 and +46
I know that the +36 will work, but the suggested offset by the manufacturer is +46 Is there some reason for this? Looks? etc?? And would that require modification? Otherwise I'll just order them in +36.
Thanks.
https://www.sau.com.au/forums/topic/183076-r33-gtst-rear-offsets-46-or-36/
no idea why they are saying the 46 is the way to go. Honestly you would end up with sunken battleship stylz.
If anything i'd be looking for a lower offset than the 36 as the wheels are only 8.5 as opposed to 9. Just as a reference, i had 17x9 +35's under the back of my 32 gtst and they were spot on for offset. the 33 has a bit more guard to fill.
In my opinion, try and go for the lowest offset and widest wheels you can get under your guards. Use the offset calculator to find out how much each will stick out from your standard wheels.
Edited by adam-__-
8.5 +32's all round :D
If you aren't confident with offsets than it's worth trial fitting some similar rims before you commit. I'm 99% certain you will fit 8.5 +32's under the front with no guard mods, provided you stick with a 235 or smaller tyre.
Hey im in the same position. Just wondering stated above says 8.5 all around with +32 offset, will +35 offset make much difference, because the rim im currently looking at doesnt have +32... only +30, +33, +35 and +38 :cheers:
I have no real clue about offsets at all, so dont know what will fit the best. Any help will be great!
The only difference you'll notice with the +35 instead of the +32 is that your wheels will be tucked in more by 3mm. Go for the lowest you can and make sure you use the offset calculator to see if they'll fit under your guards.
Heres my options:
18×8.5
5x114 Offsets: 32・36・46
and:
18×7.5
5x114 Offsets: 30・38・48
If those are your only options, go the 8.5 +32 all round...forget about the 7.5. What wheels are these anyway? Just make sure too the wheels are medium disk at least so they clear your front calipers.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
