I plan to order some wheels from Japan and want to get it right. They will be 18 x 8.5 but the offset for the rear wheels are confusing me.
I have had a good read through the offset guide, and it appears 99% of people are using a +38 offset on the rears of their skyline.
Offsets offered for the rims I will be ordering are +36 and +46
I know that the +36 will work, but the suggested offset by the manufacturer is +46 Is there some reason for this? Looks? etc?? And would that require modification? Otherwise I'll just order them in +36.
Thanks.
https://www.sau.com.au/forums/topic/183076-r33-gtst-rear-offsets-46-or-36/
no idea why they are saying the 46 is the way to go. Honestly you would end up with sunken battleship stylz.
If anything i'd be looking for a lower offset than the 36 as the wheels are only 8.5 as opposed to 9. Just as a reference, i had 17x9 +35's under the back of my 32 gtst and they were spot on for offset. the 33 has a bit more guard to fill.
In my opinion, try and go for the lowest offset and widest wheels you can get under your guards. Use the offset calculator to find out how much each will stick out from your standard wheels.
Edited by adam-__-
8.5 +32's all round :D
If you aren't confident with offsets than it's worth trial fitting some similar rims before you commit. I'm 99% certain you will fit 8.5 +32's under the front with no guard mods, provided you stick with a 235 or smaller tyre.
Hey im in the same position. Just wondering stated above says 8.5 all around with +32 offset, will +35 offset make much difference, because the rim im currently looking at doesnt have +32... only +30, +33, +35 and +38 :cheers:
I have no real clue about offsets at all, so dont know what will fit the best. Any help will be great!
The only difference you'll notice with the +35 instead of the +32 is that your wheels will be tucked in more by 3mm. Go for the lowest you can and make sure you use the offset calculator to see if they'll fit under your guards.
Heres my options:
18×8.5
5x114 Offsets: 32・36・46
and:
18×7.5
5x114 Offsets: 30・38・48
If those are your only options, go the 8.5 +32 all round...forget about the 7.5. What wheels are these anyway? Just make sure too the wheels are medium disk at least so they clear your front calipers.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
