excact same cams as im going to use. Did you have ur head ported ect? So CAS bolted up fine then
Major porting, valve and valve spring upgrade as well. Adjustable gears both sides. No issues with CAS what so ever.
i just got myself a complete set of r33 gtr engine covers for my NEO. fingers crossed they bolt up although ive been told they do. Im using R34 gtr cams so gone is the vvt solenoid. Im pretty sure the cas bolt pattern is the same justed concerned the R34 NEO cas key is diff from r34 gtr!!! If its not and i change to a GTR cas i will not have any issues with the NEO ecu?
