I've got my complete CES exhaust for sale, these are the best of the best and custom made for the R34 to give guaranteed results. Best of all it's designed so well it sits up very high under the car so it's not likely to foul anything with the car lowered.
It looks fairly stock and doesn't get unwanted attention :)
see the quality of work here - http://www.cesracing.com.au/
turbo back 3" system includes
- Stainless steel HPC coated split dump pipe
- 3" Highflow magnaflow metal substrate CAT (optional upgrade)
- 3" Mild steel mid section and resonator (better exhaust note)
- Stainless steel magnaflow twin-tip muffler
Awesome flow at legal Db, it was fully installed and fitted by Trevor @ CES Racing at Meadowbrook
This system was designed to handle up to 300rwkw
Total cost was >$2400
can be yours for the bargain price of $1400ono
Hey mate,
Very keen for the front part of the exhaust too(cat inclusive). Could you let me know of a price? I might be able to pick up too.
thanks for your time.
  • 6 months later...
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
