Does anyone know if I buy a R32 GTS4 damaged will I be able to put all my R32 GTSt parts into the GTS4 shell?
Can the GTSt cross member fit?
Will my GTSt coil overs fit into GTS4?
Can the 4wd system be removed and 2wd running gear fitted?
Is the rear cradle the same?
Does the GTS4 have front wishbone suspension the same as GTSt?
I have the opportunity to get a GTS4 shell to replace my wrecked GTSt but I'm not sure if it will be possible to have everything bolt up to a GTS4 shell.
Any help is greatly appreciated.
Rgds, Grippy
https://www.sau.com.au/forums/topic/183097-r32-gts4-gtst-differences/
yes and no. the rear is all the same. the fornt is different. the chassis is totally different to an R32 GTS or GTSt... its actually the same chassis as a GTR. The hub assemblies that bolt up to the fornt allow for front drive shafts, whereas the GTSt ones dont. The rails have a kink in them to allow for these drive shafts as well, which might mean that GTSt hubs may bnot bolt up so easily.
I haven't heard of anyone doing it as the GTS4 chassis is heavier than a GTSt one, so its kinda pointless. Find out if and how anyone's fitted a RWD front assembly to a GTR and you'll have your answer.
yeah, sell your bits off
to make it into a GTS-t, you'll need RWD gearbox, remove the halfshafts and possibly get the GTS-t front subframe if you wanted to go that far
It's a waste of time, all the ATTESSA gear will still be mostly in it and make it heavy still, sell up and get a GTS-t I think
if you've got all the GTSt parts, maybe score an R32 GTS or auto GTSt sedan of some sort and swap all the parts in, rather than dealing with the headaches of a AWD drivetrain and chassis.
Thanks heaps for all the info. It seems to be as I expected with the GTS4 shell being heavy like a GTR. I think I will let the GTS4 offer go and look to find a GTST as I had before. I was really happy with the GTST anyway.
I will post my final results later when I get myself a new shell but looks like it will be a GTST.
The tough part is finding a straight R32 GTST shell as they all seem to have the same fate as mine did. Put into the wall somewhere!!!
Thanks again for all input it has been excellent info.
Rgds, Grippy
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
