Okay,
Went in expecting around 180ish rwhp, as my car was misfiring on 7psi..... *sigh*
Pulled 208.8hp@7psi (not bad for stock boost) with a power curve that looks like a set of stairs....
I gots Zorst (w/front pipe), POD, Cold Air, and stock boost...
after having a chat to steve he commented that the timing was retarded a bit, and suggested i advance it a bit for more power... what a difference that made! was able to up the boost to 11psi, no misfiring at all, and the power pulled all the way to redline... DAM.. Kym wants another run!!!!!!
Thanks for the advice steve, i'll be back to tune the new AFC and EBC real soon...
-Kym
edit - Mod :don't forget the no cat kymbo which gives about 10-15 at the rears from the cars i've seen with it and without it.
https://www.sau.com.au/forums/topic/18310-sst-dyno-day-post-your-results-mods/
  • Replies 83
I hate to steal their thunder.....but :D
There were 2 manual NA RB30's R31's both around 135rwHP
And a very sweet lookin Manual RB20DET GTS-X which put down 137rwHP
I think my wagon was a off the pace due to being auto...manuals were held in 4th, my auto was in 2nd I believe. :O
Originally posted by adam 32
strich9: so your car was misifiring cos the timing was retarded?
what revs was it misfiring at? (i only ask cos ive got a bit of a flat spot at the moment im trying to sort out)
Yep, Sure was Adam. As soon as I cas-bashed it a bit 2mm (on the cas) advance, all the misfiring stopped except for a small pop ord two between 4-5rpm. Immediately the car pulled like a train and I was able to wind the boost all the way up to 11psi. I HAD to run 7psi before or the misfire was really bad...
It also had MAJOR flat spotting before the timing was corrected.
Attached my dyno sheet :D
343.6 at 1.2 bar on std ceremic terbs with boost control going all over the place. No damage done and boost control now sorted (I wound up the boost and left the duty cycle at a default 60% which is way too high compared to what has been "self learnt" for the lower 1.0 bar boost).
Mods: HKS engine pipe, Jap spec cat, HKS Hiper Zaust, PFC with boost kit. Normal boost 1.0 bar delivered 318 hp atw previously.
Mine managed to get itself to 210.2 HP. Got to 198 with nothing tuned then Steve quickly added fuel to my top end which got me to the 210. Will have to get my S-AFCII tuned properly and wind a bit more boost into her. Might help if i make a partion for my HKS pod, damn that thing's noisy.
For mods, see signature. Note: Nothing tuned yet....
Originally posted by S13_Angel
233.7hp @ 12psi
fmic, pod, 3" zorst (turbo back), badbiki.
very impressive angel, no wonder shes such a sleeper
as for me see the sig its got all the info, theres more roomto play but i don't think it would reliable then
Guest
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
