  • Replies 83
Originally posted by Nexus_SiX
Grand total of :269.8RWHP
This was achieved with a pod; "bush airbox"; 3" from turbo with exhaust wrap and a Power FC
Not forgeting the BOV and 2 SAU stickers
Nice to meet ya too btw.
Originally posted by Steve-SST
We need to Dyno test these stickers.
You'll have a tough time. Theyre pretty bloody impossible to come across, hey memphis?
If you'd listened to me I could have saved you $25
Originally posted by S13_Angel
PSI GTSII: huh??
I told ya before ya put it on the dyno it'd do 230rwHP;)
I am also quite talented with a 'Crayola Caddy' and could have knocked you up a great dyno graph to:p
Not sure how much credability it would have held though:rolleyes: :D
zanda lol @ 13.1 on stock turbo. not unless your running 20psi
My old Red top T25G SR20 did 228rwHP on 13.3psi.....and ran a low/mid 13 on this setup....with a good 60ft Its 'do able';)
Nice result Matty
must be a nice streetable package now - swap you a drive when I get back from OS.
Thanks Gav - yeah it's not too bad - the tuning is the secret.
No worries with swapping the drive, hey, if ya need me to look after the R whilst you are away, just drop me a line!
:uh-huh:
Ohh calm down, I slept in and didnt have time to drop in at the office!
But i do have a heap of them ready to be dropped off at works auto
Also, I hate to see what my car would have got without my 3x SAU stickers :uhh:
nice to see u all - dont think ive seen so many skylines in one place haha. I was too wussie to put my car on - its nothing to get real excited about anyway.
But good job guys must admit there was some surprises in there as well ;)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
