  • 5 months later...
hey peeps im chasing a set of sunvisors if u got some let me know cheers im in perth btw
cheers
froggah
hey man
how are ya
is it me or everyone has been stealing our sun visors lol
looks like all our cars have been fitted with a full cage wen import to australia , wat you reckon boys lol
i am also looking for a pair of sun visors
cash ready to go
anyone out there lol
might do my own w.t.b post lol
anyways good luck peoples
wil speak to you soon
keep in touch
cheers anf
  • 1 month later...
  • 2 months later...
OK GUYS I CAN GET BRAND NEW SUNVISORS FROM NISSAN....IS ANYONE INTERESTED PM OR REPLY TO THIS THREAD
hey there man
how are ya
how much can you get a brand new pair from nissan roughly
let me know asap
wil speak soon
take care
cheers anf
Edited by DRIFT RACING INDUSTRIES
driver and passenger side sunvisors ready to go
make and offer since everyone seems to be chasing them
hey there mate
how are ya
just wandering how much you wana get rid of these for and if you stil have them or not
can you please get back to me asap
and wil talk to you then
keep in touch
cheers anf
Shoot me a PM if you are chasing sunvisor's. I Have plenty in stock.
hello there as well
how are ya
could you pm me a price on a pair of these , if you stil do have some in stock
that wil be greatly appreciated
and wil be waiting on your reply
talk to you then
take care
cheers anf
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
