Hi,
I need some help with diagnosing an irritating misfire problem on my car (R32GTR)
The car misfires/currently cuts out at about 4000rpm.
I've already done the usual checks and replaced/tested these items and they have turned out to be ok.
- AFMs ok
- Ignitor - swapped with known good unit
- New coils
- CAS - swapped with known good unit
- No tears, leaks in hoses and piping.
Im currently using PowerFC and no errors are reported on the sensor/sw check screen.
I'm suspecting that it might be an injector leak or injector failure?
Just thought I'd run through you guys first and see if maybe one of you have experienced this before.
Anyway thanks in advance for the help.
hi,
I've already changed the plugs and gapped them.
I've done this today and so far still no improvement:
1) Changed injectors
2) Swapped TPS
3) Swapped fuel regulators
4) Removed boost controller
The problem is still there.
I tried to slowly accelerate, it seems to be fine until about a 5-6k
But if I try to gun the throttle, if misfires immediately.
I honestly don't know whether its fuel related or sensor related.
It doesn't seem so bad when the car is cold, but as i drive it longer, it gets worse.
One more thing that I haven't tried is the O2 sensors.
According to the PowerFC reading, the O2 sensors at idle are:
O2-1 = 1.2v
O2-2 = 1.2v
But when I WOT it gives me these readings:
O2-1 = 0.6 - 0.8v (roughly)
O2-2 = 0.6v
Could the O2 sensors be on the way out?
I'm pretty certain other parts are ok.
Just want to narrow down the problem areas.
hi,
2) Swapped TPS
O2-1 = 1.2v
O2-2 = 1.2v
O2-2 = 0.6v
02 sensors wont cause a missfire at full load - unless there is a dodgy PFC tune which enables 02 operation at very high loads. To check try turning o2 feeback off within the PFC. Have you check your base timing? If your 02 sensors aren't f**ked then it looks like it may be lean. To check the pump remove the return line from the rail, place the hose into a measuring device and start and run car for exactly 30sec - then measure. You should have around 1.5L as in 3L/min of fuel flow.
It's not your O2 sensor.
Do what rob said, flow test the pump. I would be more inclined to check it before the injectors though. Bridge the fuel pump relay and time the flow into a 1L container.
Have you replaced your fuel filter? A block fuel filter is a known likely cause of missfire under load. Can sometimes be mistaken for coilpacks.
    • OK, so all I can suggest is that - if you have all the parts, and you have all the wiring looms, and you have all the electronic modules, then....it really is just a wiring problem. You likely have a damaged wire, pin, etc, somewhere.
    • Yup, bought this bad boy and hopefully it will be ready to pickup today. Had $5 credit on top of it so it worked out really well!
    • Yeah it is really until until you get a feel for it....then it is easy. Which is no use to you really. I'd buy that torque wrench. One thing from sure, many (most?) tyre shots overtighten the f**k out of wheel nuts, so don't worry if they were tighter when you tried to take them off compared to when you do them up. I've had some crazy tight ones come back from shops, quite apart from the potential damage to the thread, I can't see a smaller person taking the wheel off on the side of the road
    • Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85.   7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
    • On sale mate, $55. Sorted. https://www.supercheapauto.com.au/p/toolpro-toolpro-torque-wrench-1-2-drive/565734.html?utm_content=paidsearch-pmax&gad_source=1&gclid=Cj0KCQjwytS-BhCKARIsAMGJyzqYEnwWmhWf6gxTST_Nz06Gd2VePgyvL7lh6PWrQtbjXTsI6TqSCLEaAuaCEALw_wcB&gclsrc=aw.ds
