have had this installed for a while but thought i would finally share a picture of it
this is the homelink mirror that was included as part of hte "premium pack" on th G35 is the USA
as far as i know it wasn't on any V35 model
its features:
- homelink: up to 3 memory IR remote control (to control garage door etc)
- auto-dim: when its dark out and a bright light shines from the rear it dims automatically without you having to flip the mirror down
it cost me about $150 from eGay and came with everything needed including mirror, wiring, and wire cover
the mirror itself mounts to the standard wedge on teh window exactly as the stock one, took me less than 15 seconds to unscrew the old mirror, slide it off, and slide the new one over.
these bad boys are stock on most lexus' and other high-end cars and i am very happy with it - especialyl the auto-dim feature, its superb!
highly recommended for anyone after the luxury features
cheers,
Warren
https://www.sau.com.au/forums/topic/183123-homelink-installed/
very easy...
2 wires:
- +12V
- ground
the loom plugs into the back of the mirror and then up through the wire cover and into the hood liner. you will see that our cars already have the hole there for hte wire th go through.. its meant to be there really
then i just ran the loom across the hood liner, down the A pillar cover, and then behind the dash
i gorunded the ground to the chassis, and onnectged the +12 to the cigarette lighter, and that's it
the auto dimming feature is better than it sounds, it really is
very easy...
2 wires:
- +12V
- ground
Cool
Good to see the pics as I couldn't get my head around were the wires would go but looks very factory, well done.
Have you tried to program the remote yet?
IT doctor.. haven't programmed it yet
cookie--monster.. you can get different models of the rearview mirror WITH bluetooth, but this particular model was designed for this car. not sure if other models would fit as easily
it looks stock because it IS stock. it was made for the car and came out in the premium G35 in the USA. if you look you will all have the hole in the hood liner where the wire is supposed to go
  • 4 weeks later...
  • 1 month later...
  • 4 months later...
hi Jon,
can you put up a pic of your mirror?
if there's a lug already going into it then it already has some sort of function built into it.. thestock one has no wires going into it, i had to splice into the back of the cigarette lighter to get power for mine
Just a plain looking rear view mirror from the front but at the back as you can see, there is power going into it. Perhaps its already got the dimmer thing built in? How do I test it out apart from getting someone to highbeam me from behind?
hmmm really not too sure on this one
there's no light sensor on the front so might not have a dimmer built in, but why else would it have the wiring loom?
also, it connects to the window differently than my stock one did
try shining a torch into the mirror when the car is in your garage and see if it dims
I found out what the plug does...it disables the intelligent key and makes it stupid :D
I unplugged it today while at the lights just to see if anything stopped working...after getting to my destination, turned car off, got out and tried locking the car with the button on the door handle..didn't work..tried locking with intelligent key, didn't work..so I used my backup autowatch remote to lock.
Came back, same thing, key fob didn't work, unlocked with autowatch and couldn't start the damn car!..was having nightmares of being stranded down the coast and remembering the thread on faulty key fobs...then it dawned on me to connect the plug back to my rear view mirror and hey presto everything works again! :D tried unplugging it again and testing my theory and yes it made the key stupid again.
Anyone here have a S2 sedan with the intelligent key, try this out and see if does the same :D
  • 1 month later...
Hey Warren
I'm very interested in the mirror but for the garage door opener, auto-dimmer is a bonus.
Have you been able to program it yet?
I've opened my garage roller door button and it has little switches you switch up and down, and you do the same on the controller.
I've also checked the www.homelink.com website but the instructions to program it doesn't make sense.
I really want to buy this as there is no convenient, easily accessable place i can put the controller in my car.
Cheers
Tien
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
