350z Vs Skyline Gts-t
COATZI
 Share
if its in a street race, then i'll have to ban you for discussing illegal activities
if its in a track race, then it depends on what's been done to the car, if its stock, then refer to factory specs
if its looking pretty... i dunno, you tell me, what looks prettier, the hippo or the whale?
350Z claimed power output of 206kw (there are higher spec ones than that)
gts-t clamied power of 187kw
are they auto or manual? both have new tyres or old? male or female drivers? expierienced or average drivers? is it raining or dry? is one driver 150kg an the other 60kg? how much luggage do they have on the boot? how much fuel is each car carrying? are they both aware there racing? or is one tearing off thinking their winning an the others just driving off normally & unware?
so many different factors that really either one could beat either one
are they both aware there racing? or is one tearing off thinking they're winning and the other is just driving off normally & unaware?
ROFLMAO .... you can't say that! most people on here wouldn't have any win stories if they couldn't count those races *cough cough*
go to a toyota forum an they'll say....who cares :rofl:
im a skyline driver, stock to stock the Z's the go. but still, if there was a fresh P plate hero behing the wheel of the Z an Jim Richards peddling the gts-t....theres too many things that can account to what would "actually" win at the time it 'actually' happened
...now i wish i had driven my bros friends 350Z around wakefield to compare. My cefiro is quicker and its basically stock. but that could be the driver of the Z....
oh and his zed was the one with the brembo brakes ....not sure on model
Edited by Resin
The Zed Wins, a stock R33 GTS-t isnt that fast... And are we talking over a drag strip or track, either way the Zed will win. Cant compare the other factors in. Purely on specs the Zed will win.... Lets leave it at that!
:rofl:
Z will wipe the floor with it, that saying the comparison must be even , stock vs stock no exhaust or filters or anything other than how it left the nissan dealership also the same driver must do the laps in the Z then the same driver in the GTSt.
i once raced a 2002 wrx in my 1982 honda civic....the poor fool didnt even bother trying, cuz he knowz the powah of the rex is no match for the powah of the 22 year old 1.3ltr 4 cylinda....uleh! :rofl:
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
