  • Replies 72
When i was installing my PFC i found an empty packet of Jap lollies and a packet of unopened tissues.
But to find some coin is way better.Nice find. :rofl:
Oh and what you have there is worth nearly $10 aus
I found a photo of a japanese family having dinner at home in the sunvisor to my nissan california work wagon about 3 years ago. I still have it in there till this day. I run into every now and again when I clean the car or go to store things in the visor. They all look so happy and i've left it alone because i feel it brings good karma to the car (not had a ding in it till this day, touch wood) :)
MY GTR came with a J-POP cd in the player, i actually still have that in the glove box in the gtr as well.... also found about 10 gold coins when i was removing the rear seat to run cables for my amp .. looks like they were for a arcade of some sort..
Strange feeling knowing that the car used to be someone elses ride before you got it...
Never found anything in my car. Not even the flare!!
The flare looks like this: (Found this in someone else's car)
The flare is still in mine.I keep it there just incase i break down in fog,or i got to a spanish soccer match :rofl:
Yeah same here.
My flare is still in the holder under the dash, although it ends up on the floor from time to time because of my big-footed g/f :)
I found an un-opened packet of tissues and the original jack and tools in the rear quater.
And mine came with the original owners manual book and sleeve including the business card of the salesman!
wow they must have skipped over cleaning out my car. dodgy little fellas
had about 20 coins, plastic necklace, real necklace which is now mums, a kenwood cd stacker (despite carrozeria head unit- incompatible) under the passenger seat.
paper wise, the whole car was riddled with mcdonalds receipts, parking tickets, coupons for stuff i cant work out, those little sticker-photos of i assume the previous owner and his chicky-babe. all sorts of jazz/
+ 1 flare, which was a bit of a letdown when set off. maybe they go off?
however- a jack without a handle, and nothing else in the way of tools (pinchy mcwharfie?)
also car was delivered to me with 4 inch exhaust, illegal ride height, fibreglass body kit, no air filter and an hks ssqv. oh and 25mm spacers :)
I have the flare and;
- Found a Tomie hicas lock bar computer under the parcel shelf when installing speakers (and i checked the hicas and the spacers are there)
- Adjustable cam gears
- CRD reckon its probably got cams as the cam gears worked best at 0 deg
- Nismo radius rods (who cares they're the same length as stock)
- Braided clutch and brake lines
Previous owner didnt know about any of it
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
