  • Replies 49
Mark backed it up today with an 8.75 and an 8.8. may have been more but we left early.
Tony Wedlok debuted the 2j solara today as well. Farkin impressive. Nailed it to just over half track then got out of it and still ran a mid 7. Made a few of the bogans take notice. :thumbsup::down:
On a stranger note, Theo was 1 km away playing dyno queen at the power cruise, I would have thought he wouldnt miss an opportunity to get in some runs this close to the nats.
thanks, ended up 5th qual in super sedan... had a good weekend...
ran 8.99, 8.83 , 8.70 , 8.79 for the weekend... car ran great all weekend...
had big traction probs off the line...
cheers, mark
8.70 - qualified number 4 so far at the Nationals at Willowbank.
  • 1 month later...
Hi Mark
Well done on your all your 8 sec passes.
Is there a propper top ten list for the fastest skylines using Dot tyres in the world.
I have a list on my forum but it now needs some changes made to it.
I would like to know if you think all the times on this list were backed up ???
please let me know your best time and i will add it to my top ten list
I thought i was doing well till you knocked me back to 4th lol
International Skyline 4WD drag records
(street tyres)
1st - Croydon Wholesalers R32 GTR - NZ - ET 8.555 - Trap Speed - 165.9 mph
2nd - VeilSide R32 GTR - Japan - ET 8.61 - Trap Speed - 172.5 mph
3rd - Team Cowie R32 GTR - UK - ET 8.85 - Trap Speed - 149 mph
4th - Waste Sports R33 GTR - Japan - ET 8.91 - Trap Speed - 162.3 mph
5th - Garage Decide R32 GTR - Japan - ET 8.933 - Trap Speed - ???? mph
6th - Signal Auto R34 GTR - Japan - ET 8.99 - Trap Speed - ???? mph
7th - Endless R33 GTR - Japan - ET 9.025 - Trap Speed ???? mph
8th - Garage SPL R33 GTR - Japan - ET 9.10 - Trap Speed - ???? mph
9th - Red Zone R32 GTR - Japan - ET 9.122 - Trap Speed ???? mph
10th - Avance R32 GTR - Japan - ET 9.13 - Trap Speed - ???? mph
Keith
the croydon car that ran 8.55 was on et streets which are a rag type tyre. doesnt really count as a street radial.. correct me if its wrong....
cheers, mark
They're still a DOT tyre so it makes them eligible for Keith's list at least.
As much as I don't like it, that's the way the rest of the world classifies a street tyre. Drag your car keys along each of your ET Drags and get on the list yourself with another 8.40!!
Adrian
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
