Hey guys,
Dont have a R32 manual and wasnt able to find anything about it here in the forums...
So anyway, I am in the process of removing my gear box (32 gtr box) from my R32 GTS4. First time ive ever done this so need a bit of help on 1 or 2 things. The motor is already out so i dont have to worry about the bell housing side of things. Tonight i removed the shifter, then inspected the underside and then disconnected the clutch fork and slave, after that i removed the drive shaft from the transfer case to front diff. Then it started to get a little cold tonight so i am leaving the rest for tomorrow. Before i packed up though i noticed of coarse the speedo cable had to be disconnected, the tail shaft needs disconnecting and im aware there are supposed to be 2 plugs attatched somewhere... 1 is the reverse sensor and im not sure what the other one is supposed to be.
from my knowledge, that is all that needs to be disconnected EXCEPT for a hose i noticed. It connects to the tail of the gear box, about 1 inch directly above the gearbox to tail shaft universal joint. I'm not sure what its for, it was very dark tonight while i was working on it, so i tried tracing it back as far as i could, and it got to a point where i couldnt fit my hands any further. It appears to me like it connects to the rear diff? im pretty sure there is some sort of oil thats going to piss out everywhere if i pull this off?
Really i wanna know, what it is, and the best way to go about removing it without making too much of a mess :cheers: This way i can hopefully get the box out tomorrow before lunch time.
Thanks guys
On a GTR im pretty sure that line leads back to a hydraulic fluid reserve tank thats in the boot for the attessa. So I am guessin it will leak once u open it, best thing to maybe do is get a line lock and clamp the hose off before opening. U will lose a bit of fluid when u pull out the hose but it wont continue to keep falling out with the line lock clamping the hose....
You will probably have to bleed the whole system once u put it all back together as well.
Hopefully ur tail shaft bolts wont be as tight as mine were!!!!!!!
good luck with it all
yea ill have to follow that line more carefully in the sun light tomorrow. Might just bleed the attessa if thats where the hose actually leads, then take the hose off an aim it into a bucket to catch whats left. Yea i hope they arnt tight too.... ive had all sorts of trouble with my engine conversion project regarding tight bolts... especially on the turbo area :cheers: the bloody things snap so easy!
Yeah on the GTR that line goes to the hydraulic pump which sits on top of the diff cradle that runs the 4WD, removal will require rebleeding of the system which is not to hard, you'll have to get more fluid from nissan as it runs a special auto fluid, the other plug im fairly sure is for the neutral sensor. :cheers:
Its the attessa fluid , you will have to undo it and block the end of the pipe , don't worry blocking the gearbox side of it ( very little fluid will come out from there ).
When you re-install the box you will have to bleed the system otherwise your attessa will not work.
ok cheers guys. So besides the hose from the hydrolic pump (located above the rear diff cradle), to the tail of the gear box, where else should i expect to find attessa fluid lines? sump diff at the front? It's just that i gotta start putting this all back together soon an the information the better :D
nope just the hose at the rear of the gearbox. sounds like you've got everything else under control.
When you refill the attessa line use good quality ATF you don't need to use the nissan stuff in particular. One thing to watch out when you bleed the attessa - there are 2 bleed nipples, one at the gearbox and another up on top of the diff.
cheers Duncan.
i have a SAU post saved somewhere on how to bleed the attessa. Looks like its time is near to come in useful for me. ATF or genuine nissan.... Hmmm... I dont know the prices yet... but my bet would be that im going to go with the ATF in the end, for the reasong being that nissan never fail to suprise me with the price tags they slap on thier products... Ill do my homework on the quality between the 2 and go from there.
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
