There is a 600hp ATI balancer, which is obviously cheaper than the 1000hp. I paid about $600 for my ATI 600hp balancer, as i do not intend to make more than 350rwkw on my car.
is that cutting it a bit fine? 350 x 1.34 = 469 rwhp. what drivetrain loss are you expecting? just curious because i'd have an ATI by now if it wasn't for the cost of the bigger one.
The ATI are obviously the better balancer but the new ROSS balancers are a very good unit. Especially for under $500 (unless of course it's a GTR). Even then you can use a GTR balancer, you just need to change to larger belts.
Things have come a long way in the performance industry in the last 2-3 years and even moreso in the last 12 months. Either balancer is going to see you safely through to 9k. I know of just as many people running ATI as ROSS and none have any complaints on either one. All are over 400rwhp, 2 over 600.
yeh sorry peeps... shoulda made it more clear.. it is for an rb26. to be honest i haven't priced either through my supplier, but have just done some internet research, and the ross ones seem to be atleast 300 cheaper then the ati. i don't intend to make 1000hp, i won't push it much further then 500@wheels.. and i know of plenty of cars still using the standard balancer at that power(if its good enough for 2BNVS to make 600rwhp, then it'll b ok for 500!). but... my engine didn't come with one.. so its just an excuse to buy a better one :) ATI seems to be the go, but if the ross is substantially cheaper i think i'll go with that. thanks for everyone's 2c. muchly appreciated
Edited by sic200
My rb30det will have a GT3076 hanging off the side. With all my performance parts, i am looking at anything between 300-330rwkw. The 600hp balancer is more than enough, and i wouldn't be surprised if the balancers are "underrated" to ensure a minimum of 600hp capacity.
Also i am sure that if people are able to run big HP figures using the std balancer, then even if i exceed over 600hp, the ATI balancer would still perform better than the factory one; Or would other problems (unknown to myself) occur ??
If i assume a 20% drivetain loss: (Is this too low an assumption?)
600hp x 0.73 = 438kw (at the crank)
438kw x 0.80 = 350.4rwkw
Yep same here...comparing ATI to Ross is like comparing a merc to a mini.
i thought you had a ross balancer? I guess you made the switch? which makes you well qualified to ask which is better! :)
ok... so next question.. if you have had an ross balancer and switched to a ati one... what difference's did you notice? ie. what comparison have you done to be able to say the ross balancer is cheese, and the ati one is the cheese? are there the 2 different types in the ross brand also? ie a 600hp version, and a 1000hp version? or just the one size fits all...
We sell plenty of ross and ati balancers at work.... for alot of RB26's!
You can't really compare Ross to Ati balancers, as said its like comparing a VS SS to a R32 GTR in track performance. The Ross and ATI balancers are both made for very different setups and applications.
Ati are and always will be a top end balancer, High punishment, long lasting and just made to a much better quality.
Ross balancers are great for minimal to medium amounts of abuse, random track days etc, but if you've spent considerable amounts of cash on your RB26 you shouldn't go past the ATI units, there not cheap but when you see the quality you understand!
Most of the High HP GTRS use the ATI Super Dampner 1000HP balancers... but the 600HP ones are great for track cars, drift and just plain tough street cars..
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
