i thought you had a ross balancer? I guess you made the switch? which makes you well qualified to ask which is better! :)
no i had an N1 item on the last engine and N1 oil pump. Got a JUN oil pump this time, in an effort to keep the inner ring of it in one piece i got the 1000hp ATI item. People HARMONIC VIBRATION KILLS OIL PUMPS thats why std pumps live ok to 7000rpm N1's live ok at 8000rpm rev them any harder and they fail due to vibration. This is the reason you need to carefully choose your balancer.
Also i am sure that if people are able to run big HP figures using the std balancer, then even if i exceed over 600hp, the ATI balancer would still perform better than the factory one; Or would other problems (unknown to myself) occur ??
Can someone answer the above question?
I don't think i'll need/want to go above 350rwkw, as my car is set up for motorkhanas and the occasional track, so 350rwkw is probably already too much for a RWD car :yes:.
its not the power levels...its how hard you are going to rev it...whats you rev limit gonna be?
yes exacly. its the revs. but more so power aswell. if you have a look at the graph it clearly shows all are ok up to 7k. and after that the vibration goes of the chart.
not saying the ross one isnt any good. just they dont say anywhere that i can see that they actually absorb the vibrations.
and as for powerbond. wel.. i will take a pik of the race one thats used in v8 ute racing on a gen3 with FACTORY rev limit with reduced power from retarded ignition.
there is a good 6 degree whip going on at the crank. the circlip that holds it together has a nice grove with witness marks showing exacly how much its shaking.
its really just an insurance. just like buying a set of conrods. for that power leval. they might not break. but if they do...
Al i was absolutely committed to getting an aftermarket damper and spoke to ross and powerbond. both told me that on an RB26/30 revved to 7500 max in a non competition car (ie no requirement for a certified damper) the standard one is as good as anything. powerbond even said that the standard one is better at reducing torsional vibration than some lighter afermarket ones.
Dave i can appreciate that the ATI damper reduces torsional vibration the degree of deflection on that graph curve would presumably not be applicable to all engines? I might well be missing something.
Paul if the stock pumps live OK to 7000 then the redline of over 7000 in the RB26 is a bit scary!
Regards
I intend to have the rev limiter, on the rb30det, set to 8000rpm but this all depends on the dyno graph. I am using a GT3076 (GT30R) turbo, which is actually the smallest recommended turbo for my engine, so if the power dips well before 8000rpm there is obviously no point in reving the engine that hard.
So why does a lightened flywheel cause more vibrations than a std one?
Does it still have an effect if it is balanced?
There is a 600hp ATI balancer, which is obviously cheaper than the 1000hp. I paid about $600 for my ATI 600hp balancer, as i do not intend to make more than 350rwkw on my car.
Ok now I'm confuzzled. ATI website shows a 500hp damper and a 600-1000 hp unit. I'm not aware of a 500 hp damper hence my question re cutting it fine for 350 rwkw.
Cheers
  • 3 months later...
Cheers
Sorry for the extremely late reply; unfortunately i didn't get any email notifications for this topic :D
Anyway, just checked the paperwork that came with my ATI balancer, as your comments raised concerns, but all is good.
From the ATI paperwork:
Street/drag use: 800hp MAX, replace every 10 years
Circuit use: - 400hp replace every 5yrs
Circuit use: - 400-600hp replace every 3yrs
Circuit use: - 600+hp replace annually
Since my car is a "weekend car" with the occational track/motokhana use, the smaller balancer will suit my purpose.
The way i look at it: These have to be better than the std balancer, so no need to worry about "cutting it fine" :)
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
