R32 Rb25de Head, Q45 Afm, Blitz Turbo Timer, R33 Gtr Parts, Apexi Suspension, Updated 21/1/08 Prices Dropped!
  • Replies 59
Hey Mate have you still got the GTR Front mount. Can you send me a couple more pics and how much to post
it to Qld 4207. It looks fine is it in good nic.
r33 gtst rear bar still for sale, if so how much inc. postage to SA post code 5264
32 RB25DE head has no VVT-hence why i bought this one as it neglects any blocking off of VCT and is favorable for a RB30DOHC conversion into a 32.
33 RB25DE has VVT-if doing an RB30DOHC conv, requires welding of the heds vct oil feed. The head still requires oil to its vct, and you will need to tap into an oil gallery and run and oil feed to it. Most common fix is T ing into the oil pressure sender feed to aleviate this problem.
As above, thanks mate.
Cheers
vvt gives you more low end torque, it switches off after at a certain amount of revs
To get oil pressure to the VVT solenoid you need to run an external line from the oil pressure send hole in the RB30 block to a fitting on the RB25DE cylinder head. No machining of the block is required. On the cylinder head you just drill and tap a hole in the VVT oil gallery for a fitting that you screw the external oil line. So no machining of the cylinder head is required either.
Rear Quarter glass Left and Right hand side $50 each
And do you have the rubber surroundings for them
im also in sydney can you pm me or give me your number so i can give you a call
so in total $100 in total correct?
thanks
  • 1 year later...
hi john plz contact me on 0424558888 i am interested in some parts for gts-4 i will come to you as i am living at parramatta atm
let me know your details asap thx
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
