g'day all,
i just took the door trim off my 1994 r32 GTR to fit some sound deadening, and i can't see any side intrusion bars in there.
i know it was complied in nsw, but how should i find out who did it?
hmmm...i wonder what legs i have to stand on...what should i do?
Cheers,
M..
well....the company that complied it is named on the compliance plate under the bonnet.
So if you do want to do something about it contact them and see what they say. And if you still want to do more and they won't co-operate take it up with DOTARS.
Are you realy shure that theres nothing in there? Because the late 32GTR's came factory fited with side intrusion bars. It looks like a fairly puny little thing that runs along the inside of the doors. Ive got one in my passenger door in my 32 GTR
get pics up and make sure that you definately dont have them, after that, dont bother with the workshop, go straight to dotars and get em shut the f*ck down. if they are taking shortcuts when it comes to your safety, f*ck em!
hi all,
thanks for all the good replies, i really appreciate it.
a) i can't be absolutely sure that there is no bar in the door - if they're small i may have missed it
b) i haven't checked the driver's side, this will help me compare them
c) i've contacted DOTARS by email, no reply as yet
d) obviously if the door has no bar fitted, i'll get them put in.
it's an interesting problem - there's a moral hazard to not telling dotars, and a moral hazard to telling them...hmmm....
Edited by Meiji
cant get them put in supposedly unless the compliance shop can source Raw's compliant ones
which mine couldnt :)
suplier is in Queensland supposedly and hadnt made any yet
there right up the top not like the aftermarket ones they put in and are hard up against the outer door skin
u can no longer put aftermark intrusion bars in for RAWS vehicles they must be OEM fitted trusion bars and doors. as for trying to contact DOTARS its kinda pointless the workshop will just say they were there wen we complied it..
Who told you this? This is the opposite of what I've heard and seen recently.
This is the same as what happened to my car, as they weren't allowed to just add intrusion bars so i had to get some white doors with OEM bars fitted and paint them black
hi guys,
ok, here's a photo looking up towards the top of the door, on the inside:
should there be anything there? i don't know if there's something behind that bulging but of metal in the middle of the picture.
btw i thought the same thing as razor - that you can use oem parts for these units?
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
