hi guys,looking for a screamer pipe for my r33,if any one has one or who knows anyone that makes them in perth.my turbo is a highflow so it would sound better than a stock turbo!and yes i know they are illegal and i know about the fines!
https://www.sau.com.au/forums/topic/183337-wtb-screamer-pipe-for-r33/
Do you even know what your asking for ?
A screamer pipe should only be run off an external wastegate, which you don't have seeing as your only running a highflow. If you just want to drive around makeing lots of noise then simply remove your entire exhaust system.
yeah,i know all that dude!!!if i am going to do i am going to do it,but i have heard some that sound ok,but i am not going to do if it sounds shit,i know it will sound heaps better and if you have an external,but i am crazy :D
ive seen screamer pipes on internal wategated turbo's - they've just had a blocking plate put inbetween the gate and the turbo outlet like strich9's
ohh and jasons (hyper31's) is pure porn to the ears!!!
yeah,you guys are right,it would be better if i already had a gate on my car,but also how would it sound being that my car is auto,pretty sure it would only vent on full boost,tell me if i am wrong?i have heard hyper31s screamer,sounds insane :ninja:
Mine sounds OK on HKS 2535 - but there's a partition (totally blocked) between the exhaust output and the wastegate output :ninja:
my highflow is probably rated the same as your turbo,so it should sound ok?my turbo is a stage 3 highflow from sliding performance and is rated at 270rwkw,about 360hp at the wheels!
Its not the size or specs of the turbo that makes the noise, its the physical wastegate, and then the diameter of the screamer pipe itself has some influence.
Pleanty of china dumps with screamers for stock turbos on ebay dude, just open your eyes. But everyone has warned you.
I didn't have one put on, that's the way they are from the factory.
Yours has an open hole between the wastegate and exhaust, so it will sound like crap. Highflows still use the stock housing.
looked on ebay already!!nothing on there at the moment,only for silvia and supra!
I did a search then and found LOADS of split dumps, just do a cut and shut yourself :)
Maybe masTers was right on the devine intervention (only for you)
devine intervention,give me a break!!!my search was for screamer pipes!!!only three come up,i know there are heaps of split dumps,under nissan performance parts!
get a split dump mate or even better a justjap racing dump /front which i can then modify for you .
kermit
cheers,sounds good!will buy one in the next few months and will get you to do it,how much am i looking at to do this mate.the justjap ones are very good,i have only got a x-force mild steel dump pipe on my car at the moment.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
