My headlights seem to be aiming higher than they should and i get all these ppl high beaming me...so damn annoying
Need help on how to adjust the light beam to aim lower.
Had a look at the front headlight assembly but cant find any screws to adjust the angle. Can see 2 white cogs teeths on the headlight assembly which when turned either way does not change a thing.
Cant find much on the g35 forums as well....Im hoping I dont need to take the whole light assembly off to adjust it..
https://www.sau.com.au/forums/topic/183355-xenon-light-adjustment/
HI mate, What kink of high light you have , the standard or 06 project?
I think I can help you with that, I install my one by my self and adjust it.
easy job
Hi, I've got standard xenon 2003 coupe headlights.
yeh,
First park your car on a flat surface against a flat wall during dark.
1, Open hook.
2, start from radiator to both left and right side. above the headlight, you can see two holes, the close front one is for low beam.
3, use a screw driver dive into the hole, put the head of driver between the mental teeth and a small piece of mental.
3, the mental teeth wil match the screw driver , so do not used the flat head.
4, turn around the driver, you will see the headlight go up and down.
unitl get your prefer level.
