Hi Guys,
I have an R32 GTS that was stolen and recovered a while ago.. I did the whole rb20det swap while I was getting it back on the road.. Like most guys, I opted for a warlboro intank pump thinking it would do the job..
Well, About 6 months to the day I got it going again, the pump gave up the ghost just after it had been for its newest WOF (warrant of fitness here in NZ).. The car is my dailydriver so I had to pool all my money together and commit to overkilling the fuel system!
As a bit of a background, I make alloy car/industrial products/tig weld for a living, so I made the surge tank in house.. It was just sitting idle not finished (no mounts or a mount for the pump) when the original pump decided to go chug chug bang.
So, I purchase a Bosch 044 External from a trade electronic supply local to me ($325 +gst), 4 meters of 5/16" fuel hose (8mm) and my auto electronic mate wired it up for me..
I used a standard rb20de fuel pump as the lift pump.. this is still wired from the factory wiring, the trigger for this pump also triggers the bosch via a relay. I had doubts at first that it was keeping the tank full.. but it definitly is..
This tank was made by me when I first started welding (about 8 mnths ago)
Fittings are standard 3/8"bspt, using a speedflow -8 male weldon on the bottom (rewelded a new one after I dropped the tank landing on the taper, stuffing the fitting!)
It goes from speedflow -8male to -8female to -8 female coupler then to -8 male to m16x1.5 on the pump..
I needed the pump to connect to standard skyline fittings, I can't afford to convert the whole system to -6 from the pump to the rail at the moment, so I got a m14x1.5 to -6 adaptor and welded an 8mm nipple onto a -8 cap.. works great.
I'll never outflow this system and it is definitly overkill.. but i'm happy.
The tank is constructed out of 100x100x3mm alloy, 3mm base/top/bottom..
The spacer lugs / base are temp for the moment till I can afford an inline -8 filter, then I'll remake the base again with that filter.. I'm also going to put a proper grommit where the lines come through the body, they are sealing fine now.. but I want to be able to trust it.. it's just temp for the moment!
Any questions/criticisim feel free..
Now, with pics:
https://www.sau.com.au/forums/topic/183374-my-surge-tank-setup/
all looks nice n neat, only bad thing i see is that the earth wiring is red, wont make anything run any different but i prefer to keep my earth wires black and positive red.
Hi, The negative wiring is red with a black conduit on the outside of it, you just cant see it because it's "taped" with loom tape.. The setup works really well, just to tidy it up more to my liking i'll extend all the wiring and hide it when I redo my boot lining (The car was stolen and strippd a while back, bastards!)
Also, while thinking about it, this setup works flawlessly.. I had my doubts at first that the non turbo pump could handle the jandle.. I used to get really bad surge/cutouts when doing donuts at the burnout comps here, it's rather embarrasing.. now I get none of this, car skids like it should do..
Just wish the tyres would last longer or I had more power so I can do 3rd :happy: damn rb20det!
I really think this is a worthwhile investment for anyone that's pushing a bit of power or is smart about reliability.. Basic outlay was for the pump ($325+GST NZD) and 4meters of fuel hose ($40 NZD).. If I had more money I'd go braided lines.. as it stands I'm remaking the main fuel line from tank > engine bay out of larger stainless steel piping so I can go -8 from tank to engine.. it's way overkill, but oh well!
Edited by salival
  • 1 month later...
same in regard to wires, heres a pic of mine.
Ive lost count of how many hours ive put into it, i bought the surge tank but made the rest ;)
not finished yet, gotta polish it all etc
is that safe with the fuel so close to the battory
im putting a fibrglass cover between the 2 battories i have in the boot and the old lpg bottle i turned into a surge tank by braising a few fittings on it well c how it goes
what u using 4 a pick up pump
    • Thanks for asking the question we were all thinking!
    • Does this apply if you use an aftermarket ecu as it probably doesn't have that functionality built it? (Assuming it doesn't, in my case, apexi)
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
