Rb26dett - Engine Problems
R31 Gagz
 Share
Hey All,
Was a nice day so had the gtr out for a spin, started the engine around about 11:45am and noticed some white smoke drifting past my window. Didn't do it anymore after I got moving...about an hour later after being at the botanical gardens, started her again, couldn't notice any white smoke. Drove around a couple of corners, got to an 80km zone so accelerated quickly up to speed and then I hear this weird pop while still accelerating and then I start loosing power....basically the car wont respond just continually loose speed until I pull over into a side road where it dies on me....now the car will start and run for about 5 seconds roughly while blowing black smoke rings and then dies...if I start it with some accelerator it runs smooth for about 2 seconds then fluctuates once and dies...nothing I do will keep it running, ended up having to get it put on the tray truck and transported home, pushed into the garage with me sitting with my chin in my hand wandering what happened.
Any ideas anyone, I do have a injector leak issue which causes it to run lean sometimes and makes the engine warning light come on (was not far off getting it fixed, hope its not the cause). Running a power FC with sard 800cc injectors, greddy adj. cam gears, r34 n1 turbos running about 14psi.
Thanks,
Gagz
Hey,
Don't think its an intercooler pipe but I haven't had a good look yet so will check out. Think the afms are fine too, plugs looked fine.
Will have a closer look tonight and report back my findings, I've got a bad feeling though I've done something worse than an intercooler pipe.
Cheers!
Gagz
Hey,
Cheers!
Gagz
It sounds like a pipe , how can you say you don't think its a pipe ? Unless you know something you are not telling us . The way you described it , running very rich so much so you can get any power out of it , its typical AFM issue, you are getting unmetered air from somewhere and my guess is you popped a cooler pipe .
You can't see the lower 2 pipes as they are inside the the b/bar , if you take the blinker grills out you should be able so see if the pipes are ok , if you can't see the top try pulling it your hand . You may have to pull the inner plastic guard to secure it if it came off.
doesnt anyone else think the engine has popped?
-smoke on start-up
-leaking injector
-engine light 'on' (detonation when using powerFC)
-pop or bang noise
"causes it to run lean sometimes"
All this doesnt look good.
If you cant find any hoses that have popped off then get a compression and leakdown done
-smoke on start-up
-leaking injector
-pop or bang noise
It may have one or more ringlands busted but that is not the reason she won't run or the fact that pumps out heaps of black smoke ( thats fuel) . Don't forget even with a couple busted ringlands you usualy have some compression , say 70psi and with boost the busted cyl still fires and what about the other 4 or 5 healthy cyls .
i agree. :)
-smoke on start-up
simply water vapour from the combustion process - nothing more, nothing less.
I agree that it's probably popped an I/C pipe somewhere. Metered air is not reaching the cylinder, causing extreme richness of mixture.
Popped a turbo/IC hose.
I did it at Phillip Island with everything hot and because of the overfuelling it melted my rear bumper and tail light.
It went POP and had no power and had a very rich exhaust, like 2m flames.
yeah what i was getting at was, he doesnt think its a pipe after a quick check
black smoke would indicate a leak and un-metered air going into the engine-i agree :)
I meant there may well be damage (such as ring lands as said, overlooking the black smoke) from a leaking injector. I wouldnt drive the car at all until it was checked if it were mine because theres a chance youve already done some damage and it may only get worse with continued lead footed-ness :D
Hey All,
After closer inspection, it WAS an intercooler pipe. The pipe on the inlet/passenger side of the intercooler had come off and had a gap big enough to put a couple of fingers in but was hard to see from casual glance as its half hidden by an air guide for the oil cooler.
My intercooler inlet/oultet and pipes are all lipped and clamped really good, this is why I thought it unlikely to happen but had some repairs done recently on the front bar and I think they had the pipes disconnected at some stage so they probably didnt put it back on properly :)
Thank god it wasnt anything serious :blink:
Thanks everyone for all your help and input.
Cheers!
Gagz
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
