Hey skyliners,
Recently had a power fc & boost controller installed on my car & for some reason the power delivery stops once the car reaches the 180kw mark.
My tuner said for my mods my car should've easily hit the 200kw+ mark. I'm taking it back soon so he can see what might be causing the restriction but I thought maybe some of you might be able to shed some light or give any suggestions or tips.
Car is an R34 GT-t 1998 coupe.
My car still has the stock turbo so hi boost is set to 12 psi, lo boost at 9psi.
My mods:
- Split 3" engine pipe bought from powerplay imports in sydney
- 3" JIC magic dump pipe
- 3" hi flow X-force cat bought from Just Jap
- HKS hi-power silent cat-back xzorst
- Apexi Power FC
- Greddy Profec B spec II
- HKS mushroom pod with CAI & modified factory snorkel
- Hybrid GT spec intercooler
- HKS SSQV type bov plumback
- Nismo fuel pump
- Splitfire coilpacks
The car itself is running well is serviced regularly.
Hope somebody out there can help
thanks in advance people
:P
https://www.sau.com.au/forums/topic/183416-need-help-guys/
  • 3 months later...
It's the boost controller. It should be able to hold 12 psi to the end and it's not. The AFR's are too rich up high as well but fixing that will only get you another 5rwkw or so. If you really can't get the boost controller to hold the 12 psi then you might have to look at putting some preload on the actuator or replacing it with an adjustable one.
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3529736
Is that a common occurance with the Greddy Profec B specII?
would getting another type of controller fix the problem or can it simply be fixed at the tuners?
Thanks again for all the replies guys! :devil:
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3530118
i got 199kw with 11psi stock ecu, exhaust cam gear, exhaust, intake, and 34 smic which surprised the crap outta me.
dunno about the profec but with the blitz one i got if you set the gain too high it over boosts past the limit and retards the ratio to settle it back down. once you get the combo of gain and ratio right it holds boost fine. maybe check if your ebc has those parameters to play with.
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3530140
One more thing worth trying which was the case for me...i had an x-force "hi flow" cat which was shit...i changed it to a 3" metalcat and got it retuned...my tuner managed to dial in more timing and peak power rose by 12rwkw...with heaps more in the midrange too...
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3530142
which is what i was about to say. its running rich in the higher rpm which is why you made the power u did. If you had 12.0/1 top end which is still stoichometric id say you would pick up another 5-10 rwk.
but it is very safe the way it is also :devil:
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3530253
I've got that aswell, so you reckon metalcat is the way to go... cheers
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3530394
Gutting the cat is silly as it leaves a large void where the gases expand then squeeze back down which introduces turbulence as a result back pressure. All though still better than having a restrictive ceramic cat in place its not as good as a straight pipe. If your going to do it do it properly and weld a pipe through the guts of the cat.
BUT..
Metalcat FTW
https://www.sau.com.au/forums/topic/183416-need-help-guys/#findComment-3530838
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
