thanks....but the offers im gettin are ridiculous and its annoying the SHIT outter me...
11k?? pffft get F*^*D!
Still for sale?
On drive.com it says 70k km's, here it says 95k?
Selling for any particular reason?
Free bump :)
We do trades, if you're interested in an R34, drop by for a chat.
cheers,
david
sorry ye i made a typo on drive.com then
and yes still 4 sale :)
reason of sale: Im upgrading to an R34
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
