I've found something i am rather interested in. but it doesnt look right... compared to the other prime edition stageas i've seen on the web
why is there no sports style shift?? is this a different version from prime edition?
cheers :D
Edited by Angus Smart
https://www.sau.com.au/forums/topic/183446-possible-stagea-purchace/
cheers :D
Yes, some series 2 Neo Stagea's do not have the tipronic gearbox
Cheap base model car. They are not very common.
I would not buy it for that reason
I just had a closer look. That car is a series 1 (black dash dials, not white), so it it would not have a tipronic anyway
But my last post is still correct, very few series 2 did not have tipronic either
Did some more searching
Here is another series 2 with No tipronic, but with black dials
So my second post was wrong about it being a series 1
Maybe some of the first series 2's, nissan was cleaning out the series 1 auto gearbox cupboard, until they swapped over to the tipronic gearbox?
http://www.skylinesaustralia.com/forums/in...2&hl=stagea
Yeah - I have seen a very similar bastard child S2 tha had no triptronic. It did have the white faced gauges though, and it also had the Neo engine so I have no answers for you there. I can say that the one I saw I would still consider because it had a very unique level of trim and some very nice bits 'n pieces (Dayz bar, among others)
If you like the car then just evaluate it on its own merits, not wether it has everything a RS4 has. You may even save a few bucks on it and it would be a great base for a manual conversion later on.
hmm can we call it a S1.5 stagea? (joking).
I'm assuming it does still have the NEO engine?
but no transmission oil cooler? (guessing).
I cant imagine resale value of these models being any higher than a standard S1. Just my opinion though.
looks like a 25x series to me which did come with leather and wood satnav etc but black dash and no triptronic there was a red one on jpsec for about 12 months like it...............http://history.nissan.co.jp/STAGEA/PAGES/MC0831/index2.html
Mike is absolutley correct!
This is a 25(t) X FOUR with optional olive grey leather (heated) seats. (velour was standard)
It has the optional Momo Wood combi steering wheel
All the X & G series came only with the E-ATx box (non tiptronic)
This is NOT a prime edition.
Is it a 98 model....they seem to have different front grill compared to S1 and S2 versions. This may be the case for the car you are looking at. Pretty sure these ones do not have the NEO RB hence no tiptronic.
EDIT: Just saw post #6 about 2000 model.....there goes my theory blown out the door. :P
Edited by Topkart R33
The grills with the bars in them are the lower-grade X- and G-spec models. This one below is a WH-C34 20G, which means it has an RB20DE and auto box. The series 1 version of the 20G didn't even have DOHC - how much would that suck! A two-litre, single-cam, automatic struggling with the weight of a Stagea...
More information...... HERE!
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
