Quick Question
Adz2332
 Share
If you keep your GTST, just make sure you get the vented bonnet and flared guards, before you get it dyno'ed! They help :ninja:
No really: think about what you have to drive every day. I could have bought an older GTR for what I paid for my R33 GTST, but I like climate control and 1/100th of the road noise etc. Plus if this car really IS stock as a rock, you should probably replace ALL the suspension bushes and stuff (like 2K worth) because if they are the original items, they will be p1ss p00r by now! Having said that, I've gotta replace my cradle bushes cos they are already shot (which surprised my mechanic) :rant:
Think about this: can ANYONE on this forum honestly say they bought a skyline (ANY vintage) and didn't have to spend more than just a few hundred bucks on it within the first year? DON'T buy a car if it's gonna leave you with nothing. Maybe it's better the devil you know :)
  • Replies 49
yer thats true.. i dunoo would like to upgrade the gtst to 270kws and then drive a 250kw gtr and see what i prefer
Maybe just spend the money on the GTST until your happy with it.
Then save up some more cash, sell the GTST and get a really good GTR from Japan, something thats already been moddd slight, maybe bigger cooler, exhaust, bigger turbos.
All you would need then would be a tune and away you go.
Bit more information to confuse the shit out of you. :ninja:
yer gee thanks thats exactly what i want more confusion...
say i do upgrade the GTST and the internals let go, what would i be up for $$wise?
Probably be cheaper just to buy another RB25 bare motor, anything from $1000 - $1800.
There is no reason the motor should let go, unless your clueless and run stupid amounts of boost on stock ECU, or don't service it regularly etc..
Just make sure whatever you do to it, you get a good tune done!
If for some reason it does let go, you'de be looking at spending about 2 - 3k and get a forged motor done, depends how forged you go internally, (eg: rods, & pistons, or just pistons)
Edited by abu
i already have a power fc and controller and its always tuned by boostworxs.
Mate,
THERE IS NO SUBSTITUTE.
GT-R.... YOUknowit makes sense......... you'll always think at the back of your mind... IF ONLY I had got a GT-R.
KW's are one thing, being able to use them is another.
GT-R, designed to be driven.
Mate,
hmmm yer
yer thats the other prob hate the dark grey colour of this car!
what turbo would i need to look at to push high into the 270kw mark?
Its a daily driver so less lag the better. and i want it to last so ball bearing would be good.
cost??
cost??
GT30R
GT3540
Either of those should do it.
Edited by abu
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
