Wheels And Tyres $400-$500'ish...
Birth
 Share
Hi there,
I am after some rims and tyres.
Stock Nissan rims and tyres (preferably good tyres) to fit my R32 GTSt (5-stud). I would go for some R32 GTSt rims with good tyres, maybe R33 GTS25t rims, I would definitely go for some V35 rims or R34 GTt rim. I may pay more for R32 GTR rims etc etc.
I am happy to consider other rims too as long as you are willing to part with them for $400-$500ish
What I will pay will definitely vary with the contidion of the rims and tyres.
Thanks,
Ben.
Edited by Birth
Hi Ben,
I've a set of 18' rim that was just used to fit onto my V35 (non brembo) for compliance purpose so they are in really new condition. (They were only used during the compliance). The offset is 35, so it doesnt clear Brembo brake. It also doesnt clear R33GTST because the caliper is too big/wide too. However, i m not sure about if it can be used on a R32 gtst or not. It looks great as u can see from the attached photo. It is also extremely light (8.7kg per rim).
Also, I've a set of tyre to match the rim. The tyre is 99.99% new as well, because it was used for compliance work only. I'd say it was driven for less than 5 kms.
If u r interested in buying them, please pm me and we can go from there.
Cheers, Frankie
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
