Have never seen one in this country, but the front grille and headlights often turn up on Yahoo Auctions ~ Japan, but they want a bomb for them as anything R30 is now cult status in Japan. An HR30 coupe like Harry's old car used to sell at auction for about 150000 yen, but today your lucky to get anything reasonable for about 500000 yen.
https://www.sau.com.au/forums/topic/183474-r30-wagon/#findComment-3325859
if someone was after a true one of a kind (in australia) then this would be it....
harldy anyone out there actually knows what this is (or recognise it!)
if i was fully loaded, i would bring it over, take out all the running gear and rebuild it all and then put it in a shed, then drop a nice Rb30, CA18det, RB20det.... L28et whatever the budget desires
one day (like 10 years) this car with all the origional gear in it would be worth SHITLOADS
(so make it last till then, and put the z18 thing back in etc...)
https://www.sau.com.au/forums/topic/183474-r30-wagon/#findComment-3325979
yeh i was lookin at the black thing!...SHINY!!!
there are alot of R30 available for minimal cost, but hardly any are good enough for compliance, and thats where the money is for the importers!
i do know of an importer with 15 DR30s, one with a FJ24det....... but thats his personal one!
https://www.sau.com.au/forums/topic/183474-r30-wagon/#findComment-3328236
I would kill to have an FJ24... and a turbo conversion aswell??? f**k im jealous that engine would be worth a fair fortune.
I did hear DR30's are easier to come by then R32s these days in Japan... when you see pictures of the car yards over there full of DR30's I can see why.
How come most arn't good enough for compliance??? they are in shitbox condition? or to do with other things?
https://www.sau.com.au/forums/topic/183474-r30-wagon/#findComment-3329558
mostly because they are 20+ years old now and most are in fare condition, you could import one your self but to import places only the good condition examples will make them profit $$$....
an FJ24 alone is a very sort after engine and worth a mint to any nissan fan, could be worth more than most of our cars.
i remembe reading an artical about the fj24 around 10 years ago and they were very rare then...
https://www.sau.com.au/forums/topic/183474-r30-wagon/#findComment-3330385
    • Ohh even easier.   Go dial up 700rpm on the hand controller. Rip off the TPS plug, wait till the idle drops and then adjust the IACV screw so it's just a tad below the target on the hand controller (say 650rpm), plug the TPS back in and idle will climb back to target. Done.
    • Hey Sleepergm, I love your inlet piping, do u mind sharing who did the work, please? cheers, Ian
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
