Ok, so things aren't quite right yet. Using a better ground has stopped the headlights from changing the reading and it will now show the correct reading for a while, but after a short time it stops working and pressure drops to 10-20psi. I'm confident that the wiring is sorted now, so the problem is with the sender. I'm thinking it could be:
1. Faulty sender
2. An air bubble altering the reading
3. Thread tape blocking the opening
4. Fuel flowing straight past the opening and bypassing the sender
Anyone had a similar problem?
have you considered the gauge setup is ok? your fuel pressure could be low.
my fuel pressure gauge is currently fine but I do need to rewire my oil pressure and temp - they are both misbehaving. most car gauges are very sensitive and only run 1v max. as a result they are very suseptible to interfearance
yet to find any guage that is tested for accuracy
just checked autometer website adn Defi - no listing of the range of accuracy available.
I was talking more about independent testing, such as the Auto Speed ones (albeit dated now, they are a good comparison between OEM companies like VDO compared to flashy looking companies that aren't concerned with accuracy)
Link 1: http://autospeed.com/cms/A_1008/article.html
Link 2: http://www.autospeed.com/A_3032/hDg34uLtp_1/cms/article.html
Yeah I did consider that but given that the car is running fine I'm fairly sure pressure is higher than the 0-10psi the gauge is showing! Either the sender or gauge is playing up, I just need to find time to work out which it is.
1. Faulty sender
the pressure would be around 40psi on a stocker, and woudlnt really vary that much when you give it a hit. + if your pressure was low your car would probably not be running rite.
its either the fualty sender, or possibly the thread tape, but in that case it wouldnt work at all.
wouldnt be an air bubble coz it would just clear itself within a split second, and definatly not no.4
its probably just the sender.
just so you know, I have an autometer boost gauge and a profec b and both gauges read identical (dont think the profec b is gonna be wrong!) just to give you an idea of accuracy, is I know its only boost and the electronic fuel and oil may be a bit more complex..
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
