cost to fix guesses to if possible ?
pulling the engine apart today to get the head faced ready for Tomei H/G saw this
I have limited Tech knowledge when it comes to engines and these sorta things
someone told me that the cyclinder may have just not been running right i.e coil pack issue or something
Edited by 1400r
https://www.sau.com.au/forums/topic/183480-burnt-valve-oil-on-valves-update/
may as well chuck a set of new valve stem seals in while the heads off, from the first pic it looks like it had a manifold gasket leak out the side, which would not indicate any valve damage.
but yes, do the stem seals and check the valves and seats out that chamber that looks sus for any damage. If you do then a reseat might be needed./
Well just had the V8/truck engine builder from the shop next door tell me he thinks the rings are shot in my motor
due to the amount of oil covering the valves
he said if it was him he would through in a set of rings and bearings and maybe linish(sp) the crank if it needs it
he also didnt like the look of the oil on number 1 valve either
yippee :)
my bosses business partners are happy to through in above items in for me
just wondering if I should put in a little extra cash for better bearings or rings than standard Nissan items?
Im leaning towards ACl race bearings but Im not sure on the extra cost seeing as were I work will have to foot the bill for the repairs
I would love to go forge bottom end but I dont think the budget will stretch that far and I dont want to complicate this for the guys putting together the motor for
me seeing as they mainly work on commerical vehicles
plans are to skid the motor already have h/g for it one hoping to make 280rwkw out of it but for now standardish power
Edited by 1400r
she does look pretty sad.
hows the bores. any scratches? how was it running prior to pulling it down? and was it smoky? there is a lot of oil in all the cylinders from the look of things. did you do a comp test?
doesnt look like a burnt valve. more like 300000k old motor gunk build up.
nice thanks that makes it worse lol
just bought the motor s/h so no idea on how it was running
engine builder said the bores looked ok probably just need a hone
unfortunately a mate cleaned the bottomend before the engine builder had a chance to look at it
but he did the push on the piston left to right thing and you could seen the oil moving around the rings
nissan rings are the best. bearings are all much the same so long as the clearances are ok. ie 2-2.5 thou on the mains and 1.5-1.7 thou on the bigends.
standard pistons with 1.3-1.8 thou piston to bore clearance.
from the sounds of it its got busted ringlands. but pull the pistons out and have a look.
got the motor s/h through my work so doubt it was running ethanol in Japan
I like to do forgies but will see dont want to over complicate things for the engine builders and it may be asking a bit much
of them to put it together for me
seeing as its only a free freshin up job
mate, putting forgies will make the job easier.
when you put second hand pistons back in, there will be 6 different pistons, and 6 different bores, all with different wear. If you put new forgies in you get much easier and more consistent clearances
Reason I asked is recently I pulled the head off mine. no oil in the inlet ports, exhaust ports just a light soot over them.
Bores perfect, no scuffing or glazing.
The combustion chambers and pistons were clean, inlet valves clean but the exhaust valves where a slight tan colour.
I was told it was due to myself driving soft and the car tuned fairly lean (due to ethanol I was running and pushing 10.5-11litres per hundred), the same thing was asked of myself.. Did I run ethanol. :thumbsup:
My initial thoughts were possibly oil but was told yes it can be caused by oil but if it were oil everything would be as dirty as crap.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
