Hi Mate, auto starts are suppose to be ilegal or some shit, but i have one, it only works from the button.
My allarm need the car to be in Neutral and hand brake on before it activates. When activated, if the key is not inserted in 15 seconds, or the brake or clutch or gear pressed/selected, without the cey the car shuts off, goes into alarm mode and won't let you start it unitll you desable the impboliser.
It is great for freaking people out. My also has the output to turn a heater on but the R33's don't have a secondary heater input.
The alarm allows up to 8 minuts of preheat time, but i haven't changed this yet.
ALSO if the car is started ad droven away by somone, if they are within range, the alarm will switch the motor off from the key aswell.
It's more wenk factor, but essentially it was there so we made it all work.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3324740
Not sure what brand mine is, and i do agree it is ilegal and if stuffed up, propably bad too, like starting in gear and so forth.
I'm not sure about the easie to get arround part. My alarm has 3 points of imobolisation and 3 poits of auto start, esentially making it 6 poits, as eaven without autostart, all the correct points need to be deactivated to start the car.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3325936
paolo,
on auto cars I'm not biased - I WATCHED a MANUAL VEHICLE start and PIN a 5 y/o girl TO A WALL - I have a REASON for stating what I do. I was not responsible for the work on that car but I knew FULL well how it happened. it had a makeshift neutral safety switch that failed - car was IN GEAR and it started.
they are good for warming up or cooling cars off on seasonal times but not much else. I see it as a 'look at me ' thing.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3329591
on my mates car he hit the remote start button, car kept on cranking but wouldn't start, we walked over to see what was going on and BANG? it backfired from all the fuel, back out the intake and blew the side out of his custom plenum.
i've also heard of them doing damage to starter motors.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3329678
depends, on a diesel the car will start and drive off. (mate of mine did this as a joke in an open field with him in the car.)
in the case I saw it was a case of wrong place right time. car moved and pinned the kid!
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3339775
the car cant move when its activated in gear..
it will just stall? Chris?
Hey...........
The only car that will not move is an automatic or a car with a neutral detect switch.
Every other car will start and move or atleast jump then stall
Dont kid yourself..
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3340694
further proves your 1 track minded views on everything in a negative fashion. list some pros.
1 track mind?
I thought he just specified it can be DEADLY if not wired in correctly or if there is a malfunction. What pros are you looking for when the damn thing is a potential death trap?
And how do you people think a remote start actually starts the car? Well let a professional explain it to you.
In order to crank and start a vehicle you need to have 12V across the ignition wire, and 12v for a short period around 1-3 seconds on the starter wire. Once you have these two, the starter will turn the engine over, and the ignition will ignite the fuel. CAR STARTS.
Now what makes you think that your car is now not easy to steal? Where do you pick up your ignition and starter points? AFTER YOUR IMMOBILISER, otherwise its not going to work. So you have just given a thief an easy way to HOTWIRE YOUR CAR just by looking at your aftermarket wiring. Your immobiliser and your remotes are now useless. All someone has to do is crank the car start and drive off. Your remote which claims a KM distance has actually just been diminished to 200 metres due to buildings and trees and what not because it work on an FM band.
Dont kid yourself there is no PRO'S to a remote start alarm.
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3353340
1 track mind?
Well said!..
https://www.sau.com.au/forums/topic/183490-remote-starter/#findComment-3356975
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
