Two.06l Update (twoogle)
Starting to get our car sorted...
Finalised the run-in on Friday (did a Sydney>Newcastle>Sydney drive) this was on top of the initial dyno run-in at Croydon's and put a bit of boost in it late friday night. @22 psi on Croydons 4WD dyno it easily pumped out 461KW with the rich run-in tune in the Power FC. This was with BP ultimate 98...so with a decent (read:leaner) tune and Shell 100 in the tank i can see a figure of 500KW+ achieveable, yes over 500kw with low-mounts on pump gas. That should silence a few of the "big single" naysayers...hehe
We took the car to Newcastle Autosalon on Saturday and put it in the dyno shootout, with only 10psi we made just over 350kw to be in 1st place for Sundays finals. I turned it back up to 22psi and with the heat of the day and an exhibition hall full of exhaust gas from the other finalists (not ideal conditions) we made 450KW! This was enough to secure victory in the dyno catergory and win another 4 trophy's including the prestigious "Tough as nails" trophy for toughest car at the show.
This is by far above our expectations and a real shock to Jim and the boys at Croydon's who were unsure if this direction (sticking with twin low-mounts) we were taking with this combo would make the numbers. With race fuel and the NOS in it, it should be abosolutely ballistic.
600kw here we come.
We would like to thank Jim Souvas and all the boys at CRD for all their hard work, knowledge and patience.
Racing the car this Wednesday night if all goes well.
ill keep you posted
Paul
  • Replies 682
What was the problem the car had that kept it off the road? All sorted now?
Good question Roy, i must be careful what i say about this subject but here goes...
We trusted our car with another workshop to have some work done (custom fabrication work) Their work practices were far from what i expected from them. To cut a long story short, they allowed the freshly built engine to become unsealed and during their work some metal shavings/swarf entered the engine. The engine then had to be removed again, stripped, rebuilt and re-installed.
I must stress this workshop was NOT Croydon Racing Developments.
a little off topic but back in the day when u ran the 10.3 @ 133mph do u have a power figure for that run
398kw...i think...it was just shy of 400kw
the torque curve of that engine/turbo/cam combo was very peaky though.
the torque curve of this engine is nearly dead flat at max torque for 5000rpm...its incredible on the road.
its a completely different car....more different than 50kw would have you think.
the power does not tell the story...its the torque.
ill post up a graph
fookin jeebus paul nice result! :)
i bet u cant wait to hit the track on wednesday, good luck :)
yeah...its not too shabby for a very fat (rich) run-in tune. Will be out either Wednesday night and/or all day Friday sorting it out at the strip. All depends on when Croydon's are avail.
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
