  • Replies 682
i always though people had dog box's for clutchless shifting ? so no clutch air gap keeping you out of fourth
maybe also need some better quality hose clamps maybe wiggins clamps
Mark was constantly smashing the box when clutchless shifting...plenty of $$ overhauling it all the time replacing dog rings etc. So to keep the box in the car he has instructed me to clutch it...so i do...he's the crew chief and has plenty more experience with this stuff than i. He said maybe try 3rd>4th without the clutch but ill need to be more brutal with the stick not clutching it.
Hose clamps were the ones that came in the HKS kit...turfed them today and replaced them with the same ones Mark uses.
Edited by DiRTgarage
was speaking to JW today at work and said your new setup is very impressive. its good to see an 8sec pass is well within grasp :down: jambo is goin to be interesting thats for sure
JW...top fella...did he tell you that i snore harder than i drive...lol. Aparently i was still dozing hard this morning when he and k went to work.
Brad, ill see how this box goes. A Liberty is out of the question...an auto ?...maybe. I just want to race it for a while and enjoy it.
did it chip second???
9.5 is hooking
on the gravel out the back of the pits it did.
should have not tried 4th...if id left it in 3rd it may have gone quicker. Maybe the car has forgotten it has more than 3 gears...lol
Paul, curiosity has got the better of me, would I be on the right track if I said your Strange carbon brakes came 2nd hand via Adelaide? If so they were in my hands not more than a few days ago - as was the new set-up that replaced the Strange gear.
If I'm completely off track then feel free to forget I mentioned anything at all.
you couldn't be anymore on track. :P
Cool pic, but being 4wd would that suggest your suspension needs a lot of work? But then again your 60ft times are still good so perhaps you only need the 4wd after the 60ft to get the power down as the full high rom power hits????
Again cool pic, really need to get rid of that stripe though :D
Again cool pic, really need to get rid of that stripe though :P
We haven't even looked at suspension settings yet and i agree with your mode of thinking...a 4wd car 60's better when it sits a bit flatter. We picked up almost 2/10ths in the 60 with the low mounts getting the car to sit flat and just bob its ass a bit on launch. The coilovers have only been raised in ride height and still have the settings that we used at Superlap when we had them fitted to the circuit car.
The stripe is an advert. for Bodyform who did a bit of work on the car, Pete's a top guy and im happy to support his business and products. Although its a bit ricey its no worse than this one.. http://www.cnjmotorsport.com.au/images/gtr1.JPG
It also makes the car easily identifiable at the track as it stands out from all the other silver 32's
I think i may even wash it before Jambo...check out the thick coat of dust on it, especially the bonnet and roof.
Man you guys have well prepped tracks, very jealous indeed, well done on the pic mate, looks great, what 60s did you manage?
Edit, just saw you'd done 1.37, not to shabby at all :-)
Rob
Edited by R.I.P.S NZ
Rob
Thanks Rob. Did a 1.38 the run before and blew the turbo outlet pipe off changing from 1st to 2nd...still ran 9.8
Mate it went 6.0 @ 114 to 1/2 track. What do you think it is capable of at that boost/power level?
Sounds really promising, great to hear!
Not taking the piss here (as you well know Paul) but are you using the launch control and anti-lag to full effect with the V88?
yeah we certainly are...the Vi-PEC anti-lag is killer.
Walk..you should have came over for a chat instead of being a 'hi-vis' face in the crowd. Mark has set the logger to automatically log from 3000rpm so we have some data there to look at.
maybe you need to up grade to motec data logging like an ACL as they have 1 gig memory as we did have a chat when you were loading the car !
really...you should have maybe introduced yourself...were you with Noel and Shane?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
