  • Replies 682
nice pic that Dave took with the front wheels off the deck on launch.
nice pic paul - TWOOGLE must have so much more potential considering that your suspension isnt even setup.
what did it end up making awkw? im sure its somewhere in this thread but reading thru almost 30pages seems painful
Thanks Rob. Did a 1.38 the run before and blew the turbo outlet pipe off changing from 1st to 2nd...still ran 9.8
Mate it went 6.0 @ 114 to 1/2 track. What do you think it is capable of at that boost/power level?
Looking back I did 1.39 in the drag-r at 1740kg on ET streets so Meremere's not toooo bad off the line I suppose, its the rest of the roller coaster ride and the bumps and lack of top end grip thats the problem, Reece runs 3-4 10th quicker in Aussie easy, he told me I'd be shocked how much power you can use from 1/2 track compared with here.
On the aborted 9.7 run in the drag-r I had 5.something @ 117mph at 1/2 track and that car has gone on to run 9.4 @ 155mph on a pretty average air frield runway so you'd have to be talking 9.40-9.50 with 6.0 @ 114???
Rob
9.4 ??? on low boost?
9.4 on 29psi
turned it up 3 psi and blew the tyres off it (smoked all four right through 1st and part through 2nd) but still ran 9.7. Tyre pressures were a little high and the suspension needs tweaking before we can run more power. Its scary to think we have around 6-7 psi up our sleeve which equates to around 130hp at the tyres. Ive discussed a custom rear cradle with a supplier today with adjustable pick-up points which may be handy.
the 60' times on 29psi ranged from 1.39 all the way down to 1.36. Lots of fun :blink:
Edited by DiRTgarage
10/10 for the sig Paul your a talented boy arent you. I agree with Marko a little bit of smoke would ne nice. Or how about have 2 or 3 different sequences one staging the R doing a massive burnout etc etc you know what i mean.
Congrats Paul on another PB. I am sure that you will soon see the magic 8 pass :blink:
Mark ran 9.38 with the same set-up (turbo kit and box) with 100whp more using the clutch to shift gears. Changed to flatshifting and went to 9.0...so at least 1/10th saved on each shift as well as the added momentum gained with the increase in MPH.
The maths looks to be in my favour for a high 8...but theory doesn't always carry into practice easily.
Paul was good to meet you and was impressed when i saw you run the 9.4, pitty you broke out. did you manage to grab the next gear after all.
yes...was its pass with the car shifting properly, went into 4th like a hot knife into butter. I dont press anything other than the accelerator pedal when going through the traps...this back off when in front or pressing the brakes before the traps shits me. I should have given myself a little more headroom with the dial-in...i first decided to dial 9.47 a 1/10th quicker than my PB which was 9.57...but changed to 9.50. So it wouldn't have mattered either way. Next event ill have more of an idea and be able to bracket race it a bit better. Smashed him at the tree with a 0.02 reaction and the race was over at 1/2 track...he should have bought me a beer for letting him win.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
