you have already spent a shit load on this car using the best parts so why not just buy the gear knob. im sure $1000 compared to what you have spent already is nothing. Plus its made to work with everything else am i correct?
  • Replies 682
correct...a supplier who already has run this set-up for years is helping us out with sourcing the parts and getting it correctly set-up.
box was pulled out this afternoon and will be stripped and inspected tomm.
Edited by DiRTgarage
found one... Bosch GSS-2...around $800 delivered
http://www.bosch-motorsport.de/pdf/sensors..._shift/GSS2.pdf
Hey Paul,
If you're looking for alternatives, could a knob-button to initiate the cut and timers or sensors to lift it do the job?
A bike-racer friend of mine uses the kill button briefly... another one made a 100ms kill switch actuated by the gear lever.
Cheers,
Saliya
Edited by saliya
right...australia is pulling out all stops to have the car running this weekend...cars back in brisbane, gearbox is still on the gold coast, shifter is being modified and the associated control unit set-up in sydney and parts are being machined in adelaide and or sydney depending on which set-up we choose to use for the gearbox. Im sure Dave Barrow and Smiley in WA have something to offer to make it a truely australia wide effort. (they would probably laugh and say "just put a bloody auto behind it")
big thanks to all the guys who have offered their assistance at a moments notice to have the car ready...much appreciated and many thanks.
the world H-pattern record is 8.95...im not for a moment suggesting its going to fall but it gives us a goal to aim for.
a PB and getting the car to run reliably within a tenth each pass like it used to would make me very happy as there is no point being fast if you can't back it up each run
No help from Melbourne??? :):banana:
No help from Melbourne??? :(:banana:
How could i have forgotten the moral support from you the other night Jack... :)
But this guy Nismoid...what rock did he crawl out from under?...mate if Ben Derks was Monty Burns...you would be Smithers.
ok...dogbox is fixed...it had a few minor issues that have been sorted and should now be reliable. Shifter had to be custom made and is being freighted up from Sydney and should be here at 10am tomm. morning.
If it wasn't for the kind assistance of Dazmo (Darren) and Deano45 (Nathan) i would be a spectator on Saturday...thanks heaps guys.
Cheers
Cheers
I want to see pictures of this new sexy shifter!!
Paul got sucked into the carbon fibre injector hat of a 5.9sec Top Alcohol Dragster @ about 500ft and is currently posting from beyond the grave. His responses, therefore, are somewhat delayed.
this was actually a highlight...and the fact the car now has a properly set-up gearbox and shifter. Its so good to shift it may as well be an automatic...its very slick.
qualified and made the field...which was good considering i was racing cars up to 4+ seconds quicker than me. Got drawn against a 5.9 sec top alcohol dragster in 1st round...suffice to say i had a quick chat to the driver and told HER there would be no funny business from me at the tree and id allow her through to the next round. The thought of it getting out of shape as she was coming past me and dumping a 500 cube hemi through my rear windscreen at 200 MPH 1/2 track was enough to be sensible, follow her into stage and leave after she did.
my anti-lag is not working as the boost control set-up changes we recently made are allowing pressure to escape out the wastegate as im anti-lagging before launch. Its something that was unfortunately overlooked when setting it up...1.8-2.0 60' times are only allowing 10.2's...instead of 1.3's that the car normally does and running something like 9.2's or better.
be back on track very soon...possibly this wednesday night which will be better air and the track should still be there from the weekend.
this is a great analogy paul - u should consider changing careers & becoming a journalist
Good work Paul, what class are you running in over there? seems odd to run 9 second cars against the big drag cars, they definately dont do that here, theres a class here for all the injected drag cars and they are running around the 7 second region and compete with altered's and small rails with small blocks. The handicap would of been huge, you would of been at 3/4 track before she even left the line lol :D
so does this mean the ppg "should" be pretty bulletproof now, or still possible issues with it? Are these shifters available for anyone or whats the go in getting one? I assume it can also be used on a circuit as well or only for drags?
Send me a PM regarding info if you can mate.
thanks
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
