whats that convert to "Hg ??
If we're still talking absolute then its 30 in/hg. google "kpa in/hg conversion" and hit "i'm feeling lucky"...(duh)
If you're talking gauge, then 0 is 0 in any unit....
  • Replies 682
I heard you're offering drives in your car at power cruise... is it cool if you watch from sidelines? I want to take some friends down the straight... thanks champ
but srsly, gimme a passenger if i go, I've only ever seen this thing on the dyno...
what sort of rpm are u gonna spin this motor upto Paul? i assume your running the external oil pump setup too? I also run the similiar cams from what the specs posted on the last page were anyway, and my vacuum is about 6 below the 0 mark on my autometer boost gauge at idle and made for some real bad braking issues.
ill rev it to 9000 on pump...no more yet. Normally i like to see 9500rpm when racing with better fuel before i shift, as its still making power and good torque at that level.
Still running a JUN oil pump...no external yet.
Edited by DiRTgarage
did a nice safe tune for pump. The car was making 450KW or 600hp at around 21psi, a nice 11.5 AFR with the timing advanced 17degrees. The turbo makes full boost by 5500rpm with the external gate spring pressure only (no electronic boost control). Rev's were limited to 8500rpm, so with some race fuel, a leaner mixture, some more ignition advance, another 14psi of boost and some NOS...this things going to really move.
Big thanks to the Guilt-Tripper for crunching the numbers into the Vi-PEC V88...a great job done mate.
Yeah it was a long day.. Lots of work was done to the car to prepare it for the Dyno. I was pretty fussy and was starting to annoy paul with some of the requests before i was ready to tune it. Everything got sorted out and we only had a few hours left to tune it.
This car is awesome. So tough its just amazing how good the engine is, you can tell that it was built by a true professional *cough paul Red R Racing cough* lol :P
The gearbox took a bit to get used too, I connected Mark @ Godzilla Motorsport to have a look at the map and give it a once over before going over 4000rpm and we had a couple of things that needed to be changed, after Mark was happy with the setup it was smooth sailing all the way.. There was only a couple of videos taken because Paul was too busy making sure the turbo drain was not leaking, just as we were ready to start power runs it was decided to stop and fix the issue before taking the revs up anymore.
Here are some pics, and Videos
Niiiice!
What AFR's will you aim at as a max on pump98?
Where its at now...this tune is only set-up to run around town...im not interested in running the engine any harder on pump. Ive built this car run times as its main goal, to achieve this the engine will have to be reasonably stressed to make the power required. The ultra consistent (and ultra expensive) leaded fuel we will be using is the only petrol based product that is capable of supporting the power at a reduced risk of engine damage. To unnecessarily push the engine on an unleaded fuel is a waste of time and money. This is why we limited ourselves to the parameters Mark set when tuning it, i.e. 8500RPM 11.5AFR 24psi and 18deg. We actually tuned it under all these levels as they were advised as a maximum and not a target to reach.
Mark will be coming down next month to perform a full race fuel tune and help prep the car for the upcoming Sport Compact drag event in Sydney. He seems to think around 35psi+ is where this turbo will see the real power made. We have the spray as a back-up if the power is not quite where we think it needs to be.
We changed to a different style of plug today and did a few runs. It instantly made a 15KW gain and the engine actually netted an increase of 1psi in boost due to improved combustion. Nice
465KW to run around town on is enough to have fun with.
Guilt-Toy has got some vids to post up...i forgot to grab a print of the curve before i left today...will grab one tomm.
Well done on the results on such little boost paul, should make big power when you turn it up and tune on better fuel.
Interesting results you got from that plug change, what were the 2 different plugs?
thanks sky...the result was only 2kw short of its best ever pump fuel figure. Considering how hard we used to push the pump fuel tunes its really impressive to almost top the figure given the limits set.
the plugs were everyones favorite BCPR7ES's....we ran something colder with different style electrode...even they were not the optimum plug for the application.
i still think the plugs were not the problem why it was breaking down. i think it was the really hot fuel in the tank
Stace says it was the plugs
It only did it when we went for more boost and sounded awfully like ignition breakdown so im tending to agree with her. Disagreeing with Stace is not a smart practice. :P
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
