r32line Posted September 3, 2007 Share Posted September 3, 2007 (edited) As title says, why do so many people have rebuilds done on these engines? Are they not well built and reliable? Or are the people doing rebuilds the ones that have modded the car too heavily or driven the car with little respect on a track etc? Surely a relatively stock rb26 if serviced regularly and looked after will last as a solid engine?? Any opinions welcome Edited September 3, 2007 by r32line Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/ Share on other sites More sharing options...
r32line Posted September 3, 2007 Author Share Posted September 3, 2007 From what I have read, the main problem with the RB26 is that when raced/tracked all the oil stays around the top of the engine and when this happens it doesn't take much to do major damage.... Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325324 Share on other sites More sharing options...
Yawn Posted September 3, 2007 Share Posted September 3, 2007 Yeah poor oil control is the inherent problem Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325367 Share on other sites More sharing options...
Swiper the Fox Posted September 3, 2007 Share Posted September 3, 2007 As title says, why do so many people have rebuilds done on these engines? Are they not well built and reliable? Or are the people doing rebuilds the ones that have modded the car too heavily or driven the car with little respect on a track etc?Surely a relatively stock rb26 if serviced regularly and looked after will last as a solid engine?? Any opinions welcome most engines making double the power they were built/designed for fail before too long. Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325376 Share on other sites More sharing options...
R31Nismoid Posted September 3, 2007 Share Posted September 3, 2007 Surely a relatively stock rb26 if serviced regularly and looked after will last as a solid engine?? Well thats the thing. Keep it stock-ish. Dont chase more than 240rwkw and it will last ages. Chase more, stock turbos fail, killing motors. Oil problems can arise if you arent overfilling. But yeah, when your making double the factory power, something's gotta give and thats generally when they let go. People go for too much power without the right parts. Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325421 Share on other sites More sharing options...
r32line Posted September 3, 2007 Author Share Posted September 3, 2007 most engines making double the power they were built/designed for fail before too long. Yeah true, the only real exception is Toyota I guess, paticularly 2jz's 1 Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325423 Share on other sites More sharing options...
r32line Posted September 3, 2007 Author Share Posted September 3, 2007 I am looking at buying one that is very stock (only exhaust, and the boost restrictor has been removed - but its only running 12psi) and it made 197awkw... I don't plan on modding it any more because I will be happy with that as it is... so I was checking that if i look after it, it will be a reliable engine Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325429 Share on other sites More sharing options...
SLIPPERY Posted September 3, 2007 Share Posted September 3, 2007 "As title says, why do so many people have rebuilds done on these engines?" Because they are put in a chassis where they can be punished and provide immense enjoyment when doing so it sounds like youve got a grasp on what kills them, so you should be able to prevent it the best you can Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325464 Share on other sites More sharing options...
r32line Posted September 3, 2007 Author Share Posted September 3, 2007 Do many ppl with GTR's get the tiny oil restrictor put in to help correct the problem? or is that only if you plan on trackin the car? Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325615 Share on other sites More sharing options...
R31Nismoid Posted September 3, 2007 Share Posted September 3, 2007 Only if your rebuilding the motor really. Overfilling by 1litre avoids this problem on a stock motor, if you wish to hit the circuit Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3325808 Share on other sites More sharing options...
r32line Posted September 4, 2007 Author Share Posted September 4, 2007 Ah ok, so you would just overfill it for the track then drop a litre out when you go back on the road? Is it bad driving it day to day with one litre too much oil? I would have thought it wasnt a good idea Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3327320 Share on other sites More sharing options...
Nismo_God Posted September 4, 2007 Share Posted September 4, 2007 how much oil should i be adding for track use??? the whole 5 litres??? more??? Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3328261 Share on other sites More sharing options...
GTRgeoff Posted September 4, 2007 Share Posted September 4, 2007 This question does not have a simple one or two line answer as there are far too many variables to consider so the correct response is... "it depends". Primarily I have found the major cause to be the mechanically unsympathetic nut behind the wheel. They choose to not understand their car needs maintenance and it needs the right support mods to make the power they want. They also choose to believe the odometer when it says 6X,XXX kays on a 10-18year old car despite the interior condition which usually tells no lies, so they think it's still fresh and can be flogged a bit. An engine has a finite life and will need a basic rebuild or three sometime through a long life. I just purchased an 03 XR8 ute with just under 100, 000km and it looks pretty good compared to the interiors of a host of imports I have seen with far less than that. Not that I think the Falcon has anywhere near the same build quality, I just realise that imports have the speedos wound back in almost every case. They blow because they are: 1. not designed to make 14+psi on the stock turbos for too long, which can rupture and cause catastrophic engine damage, 2. even with the right turbos the injectors run out of capacity so detonation results and that cracks pistons and damages bearings, and 3. they are just plain tired and a number of events result in a failure. Oil surge is extremely uncommon, but the appropriate mods can help overcome the issue. filling the sump the correct amount, running the motor to ensure oil capacity is correct and then topping off again Then overfilling with a litre of oil will work until you start to brake and corner extremely hard on semis or move to slicks. Otherwise, buy the car, enjoy it and don't overdo it without providing the right attention and it will be great for a long time. Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3328360 Share on other sites More sharing options...
N1GTR Posted September 5, 2007 Share Posted September 5, 2007 how much oil should i be adding for track use???the whole 5 litres??? more??? I always used enough oil to get the level near the bend in the stick (hope that makes sense) Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3329645 Share on other sites More sharing options...
GTRsean Posted September 5, 2007 Share Posted September 5, 2007 I always used enough oil to get the level near the bend in the stick (hope that makes sense) I do the same, to keep her happy. Three years and still going strong. Put in the whole container of oil 5l and get it to bump on dipstick. Oil and filter change every 3000km, plus oil cooler and filter relocator. Link to comment https://www.sau.com.au/forums/topic/183538-why-do-rb26s-blow-spin-bearings-etc/#findComment-3329688 Share on other sites More sharing options...
