hey all
about to install my oil cooler my self and have the oil filter relocater but want to no if i can put it in upside down so that its less messy for oil changes and what not.. also its going to be sitting higher then it does on the engine will this pose a problem at all. and finnally with an 11 row oil cooler how much more oil is the rb25 going to need???
thanks dan
https://www.sau.com.au/forums/topic/183559-oil-cooler/
the only problem i see with having the oil filter upside down is that when you turn your car off the oil will rush out of it. this means that when you turn your car back on, you'll be running without oil pressure for a while before the oil filter fills up (around 600ml worth).
if you insisted on having it upside down i'd suggest having a loop in both the feed and return hoses to stop oil from rushing away from the filter when you turn the car off.
for eg, the feed line to the oil filter would look like this:
the distance at a) should be as short as possible so oil rushes up to the oil filter and starts getting distributed quickly.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3325807
mines upside down attached to the block .. so id hope so... however I do start my car and the oil gauge doesnt move for about 3 seconds .. this normal?
this is the point im trying to make. most of the filters that suit these oil relocators are off commodores (not jap) and are pretty big. alot of the ones made here, like the justjap ones, use filters off commodores.
its not normal to have no oil pressure for 3 seconds. mine fires up almost instantly.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3326645
pretty much any filter i've used had a drain back valve. and min is intalled that way (ie hole points down). it's not fool proof though, some oil still comes out when you take it off.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3326656
The filter you are referring to (the Ryco Z145A or equivalent) is off an RB30 motor, so VL Commodores & R31 Skylines. It is larger that the "proper" Nissan item, but if you have had a good look at the Nissan item (I have a spare at home) you end up thinking "Yuck, not going to use that". Or similar sounding words. The larger filter is better in that it can hold more filth before it degrades in performance. Downside is that they are a pain in the arse to fit past the HICAS unit.
Just about every filter you can buy has an anti drain back valve. It is just a bit of rubber that stops the oil draining out fron the filter. In any case filters are basically just paper/cardboard so I can't for the life of me figure out what all the fuss is about.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3326664
couldn't you just turn it upside down so the the filter screws up from underneath. i'd say that would cause less mess then removing the filter than having the filter screw up from the top. even if you have to mount it down off a chassis rail so you can get to it easily from under the car while you are taking the sump plug out.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3326835
i thought that was his original question, can he mount it upside down as in the filter's thread pointing up, so when you unscrew it, it's full of oil but held in a way so it won't spill out...I've always wondered this - it would save having to hold a rag under the filter when you unscrew it.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3327448
That's what I've done with my relocator/oil filter and it's made for some of the easiest/cleanest oil changes I've ever done! Mine's not mounted in the engine bay either, so very easy to have a tray or something underneath it and oil doesn't get on anything else :yes:
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3327477
yes that is my original questionsimple turning it 180deg so its upside down... which i will do so on the weekend when i install. just to add to the convo i was given a honda z160 oil filter however im going to use a ryco z30 which yes is off a commodore however it does look to be the same size as the nissan filter i have on there now
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3327507
the best solution is to have it so it screws up from the bottom. only problem i could see when doing mine was that the small amount of oilt in the relocator block would rush out when unscrewing the filter. still thats better than having no oil pressure for 3 secconds.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3328055
[/sup]' post='3328055']
you could fix that by running some 900 fittings from the plate. it will minimise the amount of oil thats left in the hose.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3328120
if the filter is mounted strait up like threads are pointing down to keep oil from coming out when removing the filter u can take a screwdriver and puch a hole on top of the filter before u remove it. this will allow pressure to leave the filter allow oil to flow out and u can remove the filter with no mess! i did that on my old setup on my sr20, worked perfect!
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3328153
ruff but afective. i think i was just being too picky as it is by far the best way and depending on here the relocator was mounted it would be easy cleaned anyway.
https://www.sau.com.au/forums/topic/183559-oil-cooler/#findComment-3329986
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
