Hey all just wondering if any gtst(32 or 33) wheels would fit on an r32 gtr. I am going up to Winton at the end of the month and I don't really want to be burning up my brand new 265 pirellis or ruin my 18 x 10'' Leon Hardiritt deep dishes, brag brag brag,haha.
Cheers
https://www.sau.com.au/forums/topic/183569-gtst-rims-on-gtr/
You should put equal width front and rear tyres so that you don't stuff up the attessa/4wd system?
Nah, just pull out the fuse and rip skids :P
Yeah, they fit, i couldnt put down power in 2nd, 3rd and 4th on some roads which was fun but in the rain its just frustrating - have a look;
Fronts
Rears i cant find a pic of, but yeah, the gap between the rims and the guards is just embarassing
Where about is the fuse for the 4wd system?
hey guys im new to this site. as i have only had my gtr for 4 months now......
lol i seem to have alot of fun pulling out the fuse.. but at times it just gets to to to dangerous especially in the wet even with 18x10 on the back, the amount of traction i loose is quite fun.
anyways
the fuse u pull out on the top left hand corner on the fuse box that is just about your right knee whilst driving.
when u pull is out u will see the 4WD light appear as well as the ABS..... this is normal.
cheers
  • 1 year later...
lol, spend all ur money on rims for the street then put crappy stockies on for track. people will never cease to amaze me :P
if u want to spend some time on the track spend some $$ on some decent wheels for the track. that or just harden up and use the wheels uve got on now, a lot of drifters slide on much more expensive wheels than the ones u are talking about.
no point bothering with stockies, u wont have f**k all grip, and the tyre will just flop around.
nah, as long as the overall diametre is kept constant from front to rear ull be fine, width has nothing to do with it.
the fuse box is located above your right knee whilst sitting in the drivers seat.
so on the right bottom side of the steering wheel.
Yep there is a fuse in there you can pull as well
Or
When driving turn the car off then back on (while still rolling) HICAS light will come on and the car will be in RWD mode. If the car stops moving, so you stop at lights etc the AWD with activate again
That's another way to get it into RWD mode
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
