I am putting my much loved 1997 Nissan Stagea up for sale.
- 159xxx Kms
- Full Nismo Body Kit. Professionally fitted and painted by DMD May this year.
- Apexi SAFC and SITC piggy back controllers
- Front Mount Intercooler
- K&N Pod Filter
- Full 3" Turbo back exhaust with H/F cat and rear cannon
- Twin Sunroofs and Automatic closing rear hatch and Auto headlights
- Whitline Rear cradle bushes and front camber kits
- Sard blow off valve and turbotech boost controller set to 11psi (has never been boosted past this)
- Driver and passenger airbags
- Viper alarm system with remote pager, remote start, microwave sensors etc etc....
- Has also had timming belt and waterpump changed in May this year by Mercury Motorsport. Was also dyno tuned there at the same time.
- Plus more that I have probably forgotton....
Now there are a couple of things that need to be fixed but they aren't major problems. First the windscreen is cracked (not too bad but does need to be replaced) and also the front C.V boots are split and need to be replaced and possibly the front outter C.V joints as well but am not sure. I had Mercury look over the whole car when it got the belt replaced and tune done and the only things they could find were the Split C.V boots and a small leak from the valve cover gasket. Also on the very odd occasion on hard acceleration there is a small break down from the coil packs (this is a comming RB motor problem) but I haven't fixed that yet as most of the time it doesn't happen and it didn't even show up when the car was on the dyno but at some stage they will need to be replaced I guess. Other than these things the car is in great shape and drives great and looks great.
The car is registered till 5th Oct this year but I'm selling the car unregistered but will only really need the windscreen and C.V boots (and maybe joints) replaced to pass. And other than the coil packs I can't see any where else that money needs to be spent. A nice set of wheels would really set it off though.
I'm only selling the car as I have new plans in my life now and just don't want to spend further money on the car as its only getting driven mainly on weekends if that now and have bigger priorities now.
Asking price is offeres around the $13000 mark. And I will post some pics of the interior and the windscreen crack up when I can grab my g/f's camera. Please note also that I'm not selling it with the stero (and don't have the factory one to replace it with) however I will leave the pioneer 6" splits and jaycar 6" co-axils in the front and rear doors with the tweeter in the facotry locations. They are bother the yellow kevlar type.
In the pics ignore the tape on the wing as I just got the car back from DMD and I had to leave it like that for an extra 24 hours.
Either PM here or message me on my mobile 0422 583 180
ALSO ONLY SERIOUS BUYERS NEED CONTACT ME AND NO SWAP OFFERS PLEASE!!!
Thanks guys.
Josh.
post-26232-1188826943_thumb.jpg post-26232-1188826952_thumb.jpg post-26232-1188826960_thumb.jpgpost-26232-1188826973_thumb.jpg
https://www.sau.com.au/forums/topic/183604-1997-nissan-stagea-rs4/
No sorry will not seperate any bits from the car.
**somethings I left out of the origional post***
I forgot to mention it in the first post but I'm in Brisbane too. And although I really don't want to settle for much less than $13000 I will "consider" offers over $12000 but no less. I would estimate about an extra $1000 - $1500 tops would cover the windscreen, C.V's and a set of splitfire coils (even though it rarley shows signs of the stock ones breaking up) which would leave you with a beautiful stagea for $14ish K. Also have just put new rear tyres on with the fronts still having a bit of life left in them yet.
Edited by Mr_RS4
***Update***
I will let it go AS IS for $12000 FIRM or if you wish I can get the things fixed up (listed above) with a RWC and then it will be $13800 FIRM but will require a deposit on the car for the later option.
I would really like to sell asap but don't bother offering less than what I've posted as that really is cheap enough as it is.
Edited by Mr_RS4
Bump
As said above $12000 as is or $13,800 with the listed items fixed RWC and 6 months rego. FIRM on both prices. Pics don't do it justice, don't be scared off by the couple of things that need fixing, this is a beautiful car and is in great condition for a 10yo car and just because its modded doesn't mean its been thrashed. Also cash sale only no swaps.
Bump, I really need to sell this but am still firm on the prices. $12,000 as is or $13800 (new windscreen, coilpacks, C.V's and valvecover gasket) plus RWC and 6 months rego. Either option is a great price.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
