I am putting my much loved 1997 Nissan Stagea up for sale.
- 159xxx Kms
- Full Nismo Body Kit. Professionally fitted and painted by DMD May this year.
- Apexi SAFC and SITC piggy back controllers
- Front Mount Intercooler
- K&N Pod Filter
- Full 3" Turbo back exhaust with H/F cat and rear cannon
- Twin Sunroofs and Automatic closing rear hatch and Auto headlights
- Whitline Rear cradle bushes and front camber kits
- Sard blow off valve and turbotech boost controller set to 11psi (has never been boosted past this)
- Driver and passenger airbags
- Viper alarm system with remote pager, remote start, microwave sensors etc etc....
- Has also had timming belt and waterpump changed in May this year by Mercury Motorsport. Was also dyno tuned there at the same time.
- Plus more that I have probably forgotton....
Now there are a couple of things that need to be fixed but they aren't major problems. First the windscreen is cracked (not too bad but does need to be replaced) and also the front C.V boots are split and need to be replaced and possibly the front outter C.V joints as well but am not sure. I had Mercury look over the whole car when it got the belt replaced and tune done and the only things they could find were the Split C.V boots and a small leak from the valve cover gasket. Also on the very odd occasion on hard acceleration there is a small break down from the coil packs (this is a comming RB motor problem) but I haven't fixed that yet as most of the time it doesn't happen and it didn't even show up when the car was on the dyno but at some stage they will need to be replaced I guess. Other than these things the car is in great shape and drives great and looks great.
The car is registered till 5th Oct this year but I'm selling the car unregistered but will only really need the windscreen and C.V boots (and maybe joints) replaced to pass. And other than the coil packs I can't see any where else that money needs to be spent. A nice set of wheels would really set it off though.
I'm only selling the car as I have new plans in my life now and just don't want to spend further money on the car as its only getting driven mainly on weekends if that now and have bigger priorities now.
Asking price is offeres around the $13000 mark. And I will post some pics of the interior and the windscreen crack up when I can grab my g/f's camera. Please note also that I'm not selling it with the stero (and don't have the factory one to replace it with) however I will leave the pioneer 6" splits and jaycar 6" co-axils in the front and rear doors with the tweeter in the facotry locations. They are bother the yellow kevlar type.
In the pics ignore the tape on the wing as I just got the car back from DMD and I had to leave it like that for an extra 24 hours.
Either PM here or message me on my mobile 0422 583 180
ALSO ONLY SERIOUS BUYERS NEED CONTACT ME AND NO SWAP OFFERS PLEASE!!!
Thanks guys.
Josh.
post-26232-1188826943_thumb.jpg post-26232-1188826952_thumb.jpg post-26232-1188826960_thumb.jpgpost-26232-1188826973_thumb.jpg
https://www.sau.com.au/forums/topic/183604-1997-nissan-stagea-rs4/
No sorry will not seperate any bits from the car.
**somethings I left out of the origional post***
I forgot to mention it in the first post but I'm in Brisbane too. And although I really don't want to settle for much less than $13000 I will "consider" offers over $12000 but no less. I would estimate about an extra $1000 - $1500 tops would cover the windscreen, C.V's and a set of splitfire coils (even though it rarley shows signs of the stock ones breaking up) which would leave you with a beautiful stagea for $14ish K. Also have just put new rear tyres on with the fronts still having a bit of life left in them yet.
Edited by Mr_RS4
***Update***
I will let it go AS IS for $12000 FIRM or if you wish I can get the things fixed up (listed above) with a RWC and then it will be $13800 FIRM but will require a deposit on the car for the later option.
I would really like to sell asap but don't bother offering less than what I've posted as that really is cheap enough as it is.
Edited by Mr_RS4
Bump
As said above $12000 as is or $13,800 with the listed items fixed RWC and 6 months rego. FIRM on both prices. Pics don't do it justice, don't be scared off by the couple of things that need fixing, this is a beautiful car and is in great condition for a 10yo car and just because its modded doesn't mean its been thrashed. Also cash sale only no swaps.
Bump, I really need to sell this but am still firm on the prices. $12,000 as is or $13800 (new windscreen, coilpacks, C.V's and valvecover gasket) plus RWC and 6 months rego. Either option is a great price.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
