Does boost build up quicker in say 1st gear and with a slightly larger spike than compared with in 4th gear?
My boost controller is set up at 12psi and on the dyno in 4th gear it shows somethin like 12.5psi at like 3krpm and the tapers off to like 12psi at around 7-8krpm. But then when i run it on the street and take off in 1st gear, i check the peak boost on my profec B spec 2, it reads usually between 13.5-13.8psi.
Is this just an inaccuracy in the boost controller or does it actually spike higher in lower gears?
https://www.sau.com.au/forums/topic/183636-boost-build-vs-gears/
Higher gears I find generally bring boost on earlier (If say accelerating from 2000RPM) As the turbo has more time to accelerate.
But I generally find that it spikes around a bit more in the lower gears as the boost controller has less time to react to boost spikes.
It also depends on how the boost controller is setup.
yeah it would be a mix of things that determine what it does. in higher gears it can generally build more boost as there is more load, but in low gears the boost can spike so much quicker that it goes higher before the controller knows what's going on.
  • 4 months later...
I have a GCG highflow on the rb25. 15psi is up by about 3500-4000rpm in 2nd then less than 3500rpm in 3rd and 4th.
In 1st though I think I only have 6psi at ~3900rpm and 11psi ~5000rpm.
Is this normal? Anyone with HKS2535 or GCG turbos noticed what there boost is like in 1st. The car is very quick but I reckon the stock turbo is better at <4500rpm in 1st. I think I had 7-8psi by 3500rpm in 1st with the stocker. I guess the load isn't there in 1st so I shouldn't be too tough on it.
Edited by benl1981
My understanding is that boost is pressure the engine isn't ingesting, load is time based as the higher the gear the slower the motor RPM is accelerating (therefore there's an increased resistance to air flow going into the motor)
This combined with the fact your often using more throttle to maintain adequate acceleration in higher gears results in a greater "backlog" of air in front of the motor, meaning more boost and finally more power. Its s viscous cycle 
As others have said Phil, your generally more likely to experience a boost spike in higher gears, not lower, as its these higher airflow / faster boost transient conditions that tax a wastegate and EBC's chances of responding accordingly.
In your post though, your not comparing apples to apples. How does your 4th gear max boost and spiking issue compare to 4th gear on the street?
EDIT: Noticed im talking to a dood who asked a Q 4 months ago - whoops.
Boost in lower gears can be affected by dump, zhaust size, WG flap sealing ability... and most importantly EBC.. are you running one? It's not completely easy to compare your setup to others.
Edited by GeeTR
  • 2 years later...
diggin up and old thread here....
ive got my profec b spec running 13.5psi in my r32 gtr, usual mods aftermarket front pipes, high flow cat, 3.5" cat back, pods..
if i come to a stop, reset Peak Boost, then take off hard in first, go in second gear and take it easy, if i go into Peak boost again it shows it peaked at 14.5ish psi, but the thing is i never see this displayed on the screen ? the screens shows 13.4 -13.6psi
then i did another test, reset peak boost while driving in 4th, drop it down to second and accelerate, then go into 3rd etc then cruise it, peak boost shows 13.5psi...which is good !
so my questions is why does it peak to much in 1st gear ? why isnt it displayed on the screen ? but is saved as "peak boost"??
any info would be great !
probably from boost building much quicker when it first comes on. the profec doesnt react quick enough to stop it spiking 1psi. you could help it by lowering the start boost and gain a little bit but thats gonna make boost build slower in other gears. personally i wouldnt worry, 1psi extra in first isnt gonna make the slightest difference
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
