As stated I have a 1997 Nissan skyline series 2 r33. Silver in colour.
The car is in immaculate condition inside and out with not a single scrach on the body(never been resprayed), it will not dissappoint. I have personally owned the car for about 2.5 to 3 years now and it was completly stock when i purchused it. All modifications have been done by protek automotive from day one, with me forking out my hard earned dollars, with most mods only done in the last 8 months i.e turbo, plenum, cams,injectors. (i caught the mod bug bad)
the car has 110,000km's on it. these are true km's not just another dash whacked in there which most people do. When you think about it its not bad at all for a 10 year old car. I have never had one hint of trouble with this car except fot the starter motor going about a month ago which was replaced with a brand new one. I have recipts for all work done to the car, all in all adding up to over $20,000. The car has never seen a track day or drift event.
The car currently makes 255rwkw's on 16 psi (with dyno sheets). All the car needs is a 35-40 or bigger to unlock its full potential which was my next mod (i am told it will easily make 310 plus rwkw) , but due to getting more serious with my working life i have brought a ute. I dont want to sell my pride and joy but it really is unrealistic to have two cars esspecially as i have barely driven it since buying my ute. I have tried to keep her.
SORRY for the long comments but the car really is worth it.
List of mods as follows:
ENGINE:
apexi power FC
hi flowed turbo (450hp)
custom SS 3in exhaust from turbo back. (with hi flowed cat)
custom made Plenum by CPC (custum plenum creations)
80mm billet throttle body
Tomei poncams
hi mount ss manifold (not yet fitted)
550cc sard injectors
boosh 040 fuel pump
hybrid gt spec FMIC
Z32 air flow meter
OS gieken cam gears
alloy catch can
brass button motor sport clutch (good for 300plus rwkw)
lightened fly wheel
blitz pod filter
Front and rear strut braces
All brand new hoses and lines on plenum side if the motor due to the size of the plenum including gtr radiator hose etc.
always used motul oils
sevice at least every 5,000km's
INTERIOR:
Apexi AVCR (black edition)
Blitz FATT turbo timer
Auto meter colt gauges (boost, oil and water temp)
alpine head unit (not sure of the model but its good)
focal front and rear speakers
two alpine V12 amps
Alpine type R 12IN sub (removes in about 1 min)
nismo gear knob
EVERYTHING ELSE:
Tein fully adjustable coilover suspension (fronts just rebuilt by fulcum 2 months ago, done about 500kms)
tein adjustable castor rods
19in starcorp fusion wheels (much wider at the back but i cant remember exact dimensions)
hankook K104 rubber (245 front, 275 rear)
nismo clear side indicators
12 months rego paid today 20/8/07
I know there is more but the cars in my parents garage so this is all off the top of my head.
I still have nearly all of the standard parts which you can have
I am asking for $19,000.00 ONO - With ALL standard parts.
Car needs to go.
*Please Note; Due to minimizing Pixels in images. Images may seem distorted.
This car really does speak for its self. drive it and you will be sold.
I am located in the SE suburbs of melb
All enquires are welcome.
contact me via
mobile- 0413068555 (my name is Dan)
email- [email protected]
THANKS for you time guys. DAN
Attached thumbnail(s)
Reduced 84%
922 x 692 (91.54K)
Reduced 84%
922 x 692 (118.16K)
Reduced 84%
922 x 692 (103.02K)
Reduced 84%
922 x 692 (115.35K)
Reduced 84%
922 x 692 (97.64K)
Reduced 84%
922 x 692 (121.55K)
Reduced 84%
922 x 692 (121.11K)
Reduced 84%
922 x 692 (98.98K)
Reduced 84%
922 x 692 (107.33K)
Reduced 84%
922 x 692 (153.93K)
Reduced 84%
922 x 692 (109.85K)
Reduced 84%
922 x 692 (144.26K)
Reduced 84%
922 x 692 (74.02K)
Reduced 84%
922 x 692 (134.01K)
Reduced 84%
922 x 692 (80.81K)
Reduced 84%
922 x 692 (108.69K)
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
