As stated I have a 1997 Nissan skyline series 2 r33. Silver in colour.
The car is in immaculate condition inside and out with not a single scrach on the body(never been resprayed), it will not dissappoint. I have personally owned the car for about 2.5 to 3 years now and it was completly stock when i purchused it. All modifications have been done by protek automotive from day one, with me forking out my hard earned dollars, with most mods only done in the last 8 months i.e turbo, plenum, cams,injectors. (i caught the mod bug bad)
the car has 110,000km's on it. these are true km's not just another dash whacked in there which most people do. When you think about it its not bad at all for a 10 year old car. I have never had one hint of trouble with this car except fot the starter motor going about a month ago which was replaced with a brand new one. I have recipts for all work done to the car, all in all adding up to over $20,000. The car has never seen a track day or drift event.
The car currently makes 255rwkw's on 16 psi (with dyno sheets). All the car needs is a 35-40 or bigger to unlock its full potential which was my next mod (i am told it will easily make 310 plus rwkw) , but due to getting more serious with my working life i have brought a ute. I dont want to sell my pride and joy but it really is unrealistic to have two cars esspecially as i have barely driven it since buying my ute. I have tried to keep her.
SORRY for the long comments but the car really is worth it.
List of mods as follows:
ENGINE:
apexi power FC
hi flowed turbo (450hp)
custom SS 3in exhaust from turbo back. (with hi flowed cat)
custom made Plenum by CPC (custum plenum creations)
80mm billet throttle body
Tomei poncams
hi mount ss manifold (not yet fitted)
550cc sard injectors
boosh 040 fuel pump
hybrid gt spec FMIC
Z32 air flow meter
OS gieken cam gears
alloy catch can
brass button motor sport clutch (good for 300plus rwkw)
lightened fly wheel
blitz pod filter
Front and rear strut braces
All brand new hoses and lines on plenum side if the motor due to the size of the plenum including gtr radiator hose etc.
always used motul oils
sevice at least every 5,000km's
INTERIOR:
Apexi AVCR (black edition)
Blitz FATT turbo timer
Auto meter colt gauges (boost, oil and water temp)
alpine head unit (not sure of the model but its good)
focal front and rear speakers
two alpine V12 amps
Alpine type R 12IN sub (removes in about 1 min)
nismo gear knob
EVERYTHING ELSE:
Tein fully adjustable coilover suspension (fronts just rebuilt by fulcum 2 months ago, done about 500kms)
tein adjustable castor rods
19in starcorp fusion wheels (much wider at the back but i cant remember exact dimensions)
hankook K104 rubber (245 front, 275 rear)
nismo clear side indicators
12 months rego paid today 20/8/07
I know there is more but the cars in my parents garage so this is all off the top of my head.
I still have nearly all of the standard parts which you can have
I am asking for $19,000.00 ONO - With ALL standard parts.
Car needs to go.
*Please Note; Due to minimizing Pixels in images. Images may seem distorted.
This car really does speak for its self. drive it and you will be sold.
I am located in the SE suburbs of melb
All enquires are welcome.
contact me via
mobile- 0413068555 (my name is Dan)
email- [email protected]
THANKS for you time guys. DAN
Attached thumbnail(s)
Reduced 84%
922 x 692 (91.54K)
Reduced 84%
922 x 692 (118.16K)
Reduced 84%
922 x 692 (103.02K)
Reduced 84%
922 x 692 (115.35K)
Reduced 84%
922 x 692 (97.64K)
Reduced 84%
922 x 692 (121.55K)
Reduced 84%
922 x 692 (121.11K)
Reduced 84%
922 x 692 (98.98K)
Reduced 84%
922 x 692 (107.33K)
Reduced 84%
922 x 692 (153.93K)
Reduced 84%
922 x 692 (109.85K)
Reduced 84%
922 x 692 (144.26K)
Reduced 84%
922 x 692 (74.02K)
Reduced 84%
922 x 692 (134.01K)
Reduced 84%
922 x 692 (80.81K)
Reduced 84%
922 x 692 (108.69K)
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
