Diff Oil
Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
Does anyone find that they have to tighten their alternator belt once in a while? Mine started squealing again.
I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable. Does anybody here have one? They're fairly cheap (~$3k) considering... https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
