UPDATED 27th October
Nismo R32 GTR Exhaust
Very Good condition
80mm Full Stainless Piping
Cast Stainless Flanges
Carbon fibre finisher
Mandrel Bends
Free Flowing but Quiet around town
Will support up to 350kw
Big $$$ new
$SOLD
PAIR of FRESH, FULLY REBUILT and BALANCED GTR turbos (Have not been fitted since rebuild)
These will fit R32, R33 and R34 GTR with no other mods.
The cores have been upgraded to steel exhaust wheels / shafts, 360 degree thrust bearings and step gap oil rings to ensure realiable delivery of higher boost pressures. Turbos have been VSR / Balanced.
Wastegate actuators have 2 settings. Have seen 300awkw on the same spec turbos.
Included is a Power FC File that made a safe 280awKW on my R32 (Std injectors and AFM's). If you have larger injectors or AFM's you may need a minor clean up of this tune - but the bulk of the work has been done - an hour or so on a dyno should do it (rather than 3 ~ 4 if you were starting from scratch). If you are interstate I can still load the file onto your FC if you send it to me.
Standard GTR comp cover / exhaust housing (.42 / .48)
Unleash the pontential in your GTR!
$(ON HOLD)
PM or Email Me -
[email protected]
Good set of clean Factory R32 GTR Rims
16x8 - forged
$(ON HOLD)
Edited by Antimatter
The cores have been upgraded to steel exhaust wheels / shafts, 360 degree thrust bearings and step gap oil rings to ensure realiable delivery of higher boost pressures. Turbine wheels flowed - Turbos have been VSR / Balanced.
Rated at approx 500hp - Same spec turbos have deliverd 300kw @ the wheels with minimal other mods on RB26 (Exhaust, Filters, ECU and FMIC)
$1700 the pair + Delivery
Are these off a R32/33/34? can you pls post the model #. Also the pics you have are from ebay? Do you have actual closeup pics?
Thanks for your message.
Serial from tags is 14411-06U20 and 14411-06U21 (this will only tell you what the cores began life as anyway)
I beleive them to have originally been CERAMIC TURBINE WHEELS off an R33 (have since been rebuilt and upgraded to Steel Turbine wheels, 360 degree bearings etc).
These are the pics of ebay (that was my listing). If anyone is interested I will be re-listing these soon if not sold prior.
Can email hi res images on request.
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
