Hi Guys and Gals,
Lets start off with the issue im having. When i rev the car and let go off the accelerator the car drops rpm (as it normally would) till about 1500 rpm and then goes all the way down to nearly turning off and sometimes just manages to stay on and then come back to normal idle or just turns off......
Second issue is with the new n1 oil pump in the oil pressure stays on the line between 0 and 4 (impressuming 2) when the car is idling and when you rev it, the guage just goes upto just under 4 at normal temp and just above 4 when cold. I presumed that the n1 oil pump should be putting out more oil pressure???? Thoughts??
The car has an rb26dett in it. Mods are 3inch full exhaust, bov(dont ask me wat brand, some japanese brand written in jap), hks pods, n1 oil pump & hks stage 1 cams.
We had to rip out the engine coz the car lost oil pressure so i put in the n1 oil pump and when we started it back up the above mentioned problem is happening.
Cars still at the mechanics shop
Any ideas....... Please help
Rj
Edited by 4drlvr
https://www.sau.com.au/forums/topic/183723-stalling-sometimes/
grab a mates BOV....through it on...see what happens...could have a pretty monior leak that the comp pics up and tells it to shut down...like when you blow a turbo pipe....its what i discovered with my stock BOV......and by the sounds of it...you could have the equvilent of "home brand" BOV
Edited by Nismoh
n1 oil pump runs less pressure than stock, not more - it is designed for sustained high rev use when the standard pump puts too much oil into the head.
around 2-4ish isnt really a problem for oil pressure it depends on the temp of the engine and the wieght of the oil of course
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
